Can you name all my winter goodies? (pics)
Old Nov 14, 2001 | 01:44 PM
sackdz's Avatar
Default Can you name all my winter goodies? (pics)
Here's what I got my ITR for Christmas:
Too bad the JDM FD is on backorder
What are you guys gonna put in your R's stocking?
Old Nov 14, 2001 | 01:48 PM
ThePunk's Avatar
Default Re: Can you name all my winter goodies? (sackdz)
Z-10 traction bars. Spoon light flywheel, rota slipstreams(or actual spoonies), camera mount, hawk pads, and brake fluid, and braided lines?
Good stuff!
[Modified by ThePunk, 2:50 PM 11/14/2001]
Old Nov 14, 2001 | 01:50 PM
sackdz's Avatar
Default Re: Can you name all my winter goodies? (ThePunk)
Good job.
not sp00nies. r0tas. So flame my ***. *me puts on fireman pants*
[Modified by sackdz, 5:51 PM 11/14/2001]
AssPenny's Avatar
Don't forget the goodridge ss lines
Old Nov 14, 2001 | 02:09 PM
mr2's Avatar
mr2
Default Re: Can you name all my winter goodies? (AssPenny)
man your spoiled
Old Nov 14, 2001 | 04:15 PM
Floyd's Avatar
Default Re: Can you name all my winter goodies? (white eg)
Is that camera mount designed to fit on the headrest supports? And how does that brace work? Where does it attach?
-Floyd
Old Nov 14, 2001 | 04:23 PM
Padawan's Avatar
Darth ModerVader
Can you please post more pics of the Slips?
Old Nov 14, 2001 | 04:56 PM
nsxtcjr's Avatar
New User
Default Re: Can you name all my winter goodies? (SpecR0123)
Sure. I'll name them Dasher, Dancer, Prancer, Vixen, ...
Old Nov 14, 2001 | 05:02 PM
sackdz's Avatar
man your spoiled
I'm not spoiled, but my car is
Yes. The pegs on the headrest slide through the holes. Here's the link I got the concept from: http://hybrid.honda-perf.org/contrib...t/buildit.html
Sure. hang on
Old Nov 14, 2001 | 05:13 PM
Ricehornet's Avatar
those the gunmetal color they have?
Old Nov 14, 2001 | 05:15 PM
ThePunk's Avatar
Default Re: Can you name all my winter goodies? (Floyd)
-Floyd
More about the Brace here...
http://www.z10eng.com
Old Nov 14, 2001 | 05:25 PM
sackdz's Avatar
Default Re: Can you name all my winter goodies? (Ricehornet)
Yea, gunmetal... darker then I expected but doesn't bother me... they're track wheels anyways.. heres some more pics:
Old Nov 14, 2001 | 05:44 PM
R748's Avatar
man your spoiled
Sure. hang on
Please be very careful, that thing is awfully close to the head of the driver. If the car were to be in an accident of any kind, I would not want to be the driver. Reconsider using that setup. A safer place is to mount the camera between the rear seat belt anchors. It's a bit more expensive and will make the rear seats useless, but I think your life is more important that good footage.
[Modified by R748, 6:45 PM 11/14/2001]
Old Nov 14, 2001 | 05:59 PM
sackdz's Avatar
Default Re: Can you name all my winter goodies? (R748)
I mount it on the passenger side headrest... Not that it's an impossibility, but I think that in any accident bad enough to pull the headrest/camera out of the seat, there are far worse things happening than a 2lb digital camera hitting my helmet... Until I get a rollcage, I think this is a great idea.
thanks for you concern though...
[Modified by sackdz, 10:00 PM 11/14/2001]
Old Nov 14, 2001 | 06:09 PM
R748's Avatar
It's a metal bar, near your head and neck, and it shaved on one side. Yes I agree that you will get hurt in any accident that is enough to either [1] disloge the bar from its mount or [2] move your body/seat enough to contact the bar. However, it may be the difference between decapitation and survival.
The bar seems to go between the headrest and the seat. The head-rest is NOT well anchored to the seat body, in fact, since you have the head-rest pulled up all the way to acomodate the bar, the force required on the head-rest to pry it loose is MUCH less than if the head rest was all the way down. If your car were to roll on the track and you din't have a 3-point harness you body will be thrown about in the cabin. I woudn't want that thing in the cabin, near your head.
I'd be very surprised if that passed tech inspection.
Hey it's your car and your life, I just don't want people to get hurt un-necessarily.
[Modified by R748, 7:11 PM 11/14/2001]
Old Nov 14, 2001 | 06:13 PM
sackdz's Avatar
It's a 1 inch hollow aluminum box tube. The headrest is only raised up 1 inch. There is a significant amount of play at the end of the bar (enough that I think the video might be bouncy ) Also, the ball mount itself is just a clamped ball that will deflect over 90 degrees in any direction (with a strong force), making any impact from the camera much more absorbing.
Old Nov 14, 2001 | 08:26 PM
Grandprix's Avatar
i built that camera mount. it works ok. But I developed a better way.
I use one piece of the 1 inch box metal. Its about 18 inches or so. I drilled two holes in it that are about the same size as the headrest poles. It is ABSOLUTELY ESSENTIAL that the holes be spaced perfectly and holes must be ever so slightly larger than the pegs. It may seem to move a little bit, but with image stabilization, it is absolutely smooth.
Ask Yella Dragon
Old Nov 14, 2001 | 08:33 PM
sackdz's Avatar
Default Re: Can you name all my winter goodies? (Grandprix)
It was such a pain in the *** drilling in between 2 pieces of metal. I would get halfway through, then the bit would always grab to the side. The holes are not very even at all, but with the plastic tubing, the pegs are in there tight. All the movement is from the pegs/seat itself. I know D made a bar that connected both headrests, but it would make moving the seats a pain in the ***. Which I suppose is alright for the track. I'm going to try this out first, if it is too loose, we'll see....
SKRacer
Nov 14, 2004 02:53 PM
rtype11
Nov 23, 2001 07:30 AM
mrlegoman
16
Nov 14, 2001 08:26 PM
infamousALLMTR
Nov 14, 2001 07:11 PM
