fixing camber on rear of my crx
i have herd of using washer in the rear to fix the camber but i am not sure on how to do this so if someone know inform me please. also what is the down fall of this and the ups of this. and if it is not a good idea what camber kit should i get
You shouldn't have to adjust rear camber on your car, even if it is dropped like 2.5 inches. something else might be wrong. If you have even camber in the rear wheels then your tires will rub.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9crx1 »</TD></TR><TR><TD CLASS="quote">well i have camber what do you think is wrong. my struts are bad i know this.</TD></TR></TABLE>
replace your struts. also, a little bit of camber is not necessarily a bad thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9crx1 »</TD></TR><TR><TD CLASS="quote">i have herd of using washer in the rear to fix the camber but i am not sure on how to do this so if someone know inform me please. also what is the down fall of this and the ups of this. and if it is not a good idea what camber kit should i get
so your on stock suspension then I'm assuming?
If your wondering how the washer trick work it moves the arm forward so the camber from your drop is corrected, If you do it only use 4 washers
Andrew 825SM
Aug 15, 2003 03:16 AM
