Anyone have the Haynes Suspension, Steering, Driveline Manual?
If yes, do you know who makes the tie rod puller on page 2-34, illustration # 2.106, top left picture?
thanks,
diyer
thanks,
diyer
I've had good luck using an autozone 2/3 jaw puller...except for the one that I broke 2 teeth off of... cheap taiwanese crap...but the replacement worked just fine...
$25 rental... free if you bring it back within 2-3 days...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZigenBallz »</TD></TR><TR><TD CLASS="quote">I've had good luck using an autozone 2/3 jaw puller...except for the one that I broke 2 teeth off of.</TD></TR></TABLE>
OUch..did they make you buy it??
nope... got a new one... gotta love that warranty...
Also I must apologize... I just skimmed over the first post I guess and in my mind I must've replaced "tie rod puller" with "ball joint puller"...My bad...disregard my post...
Yes, that is what I am wondering about ... Can I use a ball joint press kit to remove the tie rod end ball joint?
Tool mfrs make both a ball joint press to remove and install the ball joints, but also make tie rod pullers. Old Forge makes one but the puller arms pivot, and I like the more rigid design like the one in the Haynes manual.
diyer
diyer
Jia Gabrielle
Jul 2, 2019 03:58 PM
mickeywickit
15
Apr 16, 2017 06:51 AM
