How To Retard Timing?? Maybe Some Valve Adjustment Help
Old Jun 15, 2004 | 06:24 AM
Traction's Avatar
Default How To Retard Timing?? Maybe Some Valve Adjustment Help
Can anyone please tell me how to retrd my timing 2 degrees? Im instaling a Zex Dry 65 shot so I need to retard it 2 degrees. Looking for help on a sohc zc or the stock d16a6.
My valves also seem to be ticking a bit so I think it would be best to adjust those and get them to spec, is it very hard? ive never tried to touch any of my internals.
ANy pics or guides,links would be amazinh.
THanks
Old Jun 15, 2004 | 11:29 AM
Traction's Avatar
Default Re: How To Retard Timing?? Maybe Some Valve Adjustment Help (StealthEF)
Old Jun 15, 2004 | 11:32 AM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
have u tried searchin first? just wondering....
Old Jun 15, 2004 | 07:02 PM
Traction's Avatar
Default Re: (dgonzals)
Yes I searched, the only 1/2 descent thread I found was for a DOHC Vtec motor, and it didnt even really explain it very well
Once I take the valve cover off I really am lost lol, I dont know where to stick the feller gauge, I dont know how to get the cylinder to TDC
Found nothing on retarding an engine
Old Jun 16, 2004 | 11:30 AM
Traction's Avatar
Default Re: (StealthEF)
Old Jun 16, 2004 | 11:58 AM
EF_LSVtec's Avatar
retarding an engine 2 degrees=adjusting timing 2 degrees late...you'll need a timing light, make sure it has power and light is blinking, point it to your timing guide, usually located right by the crank pulley, then adjust your distributor accordingly.
Old Jun 16, 2004 | 12:04 PM
91hob20hb's Avatar
ok from my experience i always retarded my timing for spray via the ignition/dizzy if i'm wrong and thats not the right way to do it then damn i'm lucky i havent blown anything up yet.
Old Jun 16, 2004 | 12:10 PM
green91's Avatar
Default Re: (91hob20hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91hob20hb &raquo;</TD></TR><TR><TD CLASS="quote">ok from my experience i always retarded my timing for spray via the ignition/dizzy if i'm wrong and thats not the right way to do it then damn i'm lucky i havent blown anything up yet.</TD></TR></TABLE>
that's what i thought also, you shouldnt be taking the valve cover off, period.
Old Jun 16, 2004 | 12:12 PM
Traction's Avatar
Default Re: (green91)
so the correct way would be.... ?
Old Jun 16, 2004 | 12:21 PM
91hob20hb's Avatar
I wish i could be of more help but i usually get a friend to help me with the timing on my motors.I but i know that you do use a timing light and retard or advance the timing for spray using the dizzy.
Old Jun 16, 2004 | 01:51 PM
ServiceAdvisor's Avatar
Invest in a Chiltons or Haynes manual and it will tell you how to adjust your timing. - Darrell
Old Jun 17, 2004 | 10:25 AM
Traction's Avatar
Default Re: (OldSiHatch)
I have a Haynes right infront of me, absolutely nothing
Old Jun 17, 2004 | 10:26 AM
Full Race A6's Avatar
Is your manual for the ef civic? Thats the one I have and Im pretty sure I think Ive seen it
Old Jun 17, 2004 | 10:49 AM
Default Re: (W O T)
nope never mind, not in mine, mine is for the 84-91 Civic though
Old Jun 17, 2004 | 12:02 PM
EF_LSVtec's Avatar
Default Re: (W O T)
find out the direction your motor turns, (look at your crank pulley while motors running), to advance timing move the distributor opposite that direction your motor turns, then to retard simply do the opposite...to get the exact degree of adjustment, use a timing light.
Old Jun 17, 2004 | 12:11 PM
EF9Si-T's Avatar
I suggest you try taking it to a specialist cause if you dont do it right Youll have bigger problems, or study the haynes manual plenty of time til u get comfortable with trying to do it before you actually do it.
Old Jun 17, 2004 | 12:20 PM
Default Re: (BUG_MANIAC)
I think a shop would charge a fair bit of cash to do this would they not?
If it doesnt cost to much man, bring it to your mechanic because if you **** it up and spray, youre motor will be done
Should cost to much maybe 30 bucks? 1/2 hour of labour maybe
Old Jun 17, 2004 | 07:26 PM
EF9Si-T's Avatar
Default Re: (W O T)
Actually I charge a little less then most shops and thats $80 including new valve cover gasket, and labor is charged in full hours . So that would be about 1 or 2 hrs. deppending on the shop.
Old Jun 17, 2004 | 07:56 PM
Traction's Avatar
80 bucks eh, thats not bad I guess. Ill be doing my e-test/safety check there and its a place where my family frequents and I got my blown head gasket done there
Maybe Ill get a slight price break
Can a shop retard my timing? Like im going in there to get an etest, can I say retard my timing 2 degrees when your done or is that illegal for them?
Old Jun 17, 2004 | 08:24 PM
Doug684's Avatar
$80 is a rip off. The Gasket it only a couple of bucks and it takes about 5 min to do. Buy a timing light from AutoZone and spend 10 min to do it your self.
Old Jun 17, 2004 | 08:33 PM
Traction's Avatar
Default Re: (Doug294)
I think he meant for the valve adjustment
I dont know what youre talking about though, I dont think you need to remove the valve cover to change the timing
Maybe he can explain, and I wanna know if Im aloud to ask a mechanic to retard my timing 2 degrees
Old Jun 17, 2004 | 10:13 PM
91hob20hb's Avatar
What the crap???? $80 bucks???? to loosen 3 bolts and plug a timing light up, then turn the dizzy.At the most that should take 15-20 mins.unless its your first time.Then you wanna play with it a little bit until you figure it out.It shouldnt cost no more than $30 because even $30 sounds like highway robbery to retard or advance the nignition timing.Now i understand the vavle adjustment. Even if you wanted to retard or advance the timing on your cam/s that does take a little more work but still not $80 bucks worth.
Old Jun 28, 2004 | 06:03 PM
limey156's Avatar
how do you know what 3 degrees timing retard is exactly? i have a timing light and understand how to do it, but im not sure exactly how to read a 3 degree retard. thanks
Old Jun 28, 2004 | 06:27 PM
Curtis2kul's Avatar
Default Re: (limey156)
I just had my cylinder head rebuild (burnt a valve from a 55 shot zex dry kit) and i was wondering that to, im in the middle of taking the crank pulley off to get the timing cover off so i can align the cam sprocket with the crank at tdc. Isnt this right. Also there is only one way to put in the distribuotr correct?
Old Jun 28, 2004 | 06:31 PM
mr. carpenter's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by limey156 &raquo;</TD></TR><TR><TD CLASS="quote">but im not sure exactly how to read a 3 degree retard. thanks</TD></TR></TABLE>
that sounds funny. to advance at the dist. turn it to the firewall. to retard turn it to the radiator.
