removed side moldings ( yes i have searched)
Old Jun 15, 2004 | 05:44 AM
rough_draft's Avatar
Default removed side moldings ( yes i have searched)
what does it look like under the side moldings? I was thinking about taknig them off but i dont want a bunch of holes and such behind them.. Are they just glued on? Could i take them off and then remove all the adhesive stuff behind them and would i be done with it? Thanks
Old Jun 15, 2004 | 06:23 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: removed side moldings (rough_draft)
You'll be visiting the body shop or parts dealer if you remove them. There are a series of holes that the clips go into to keep the molding on. You could get them filled with body filler or go have them steel welded and sanded etc. Either way the doors and body will need to be painted.
Old Jun 15, 2004 | 06:59 AM
deejaycherub's Avatar
there are nine square holes on each side if you decide to remove them. 6 on the door and 3 on the back quarter panel for each side. there is not adheisive glue, just clips. so if you dont want to get your door re-done, leave it alone.
jdmchino12
Dec 1, 2010 06:51 AM
Eagle16nam
Feb 5, 2006 09:47 PM
Quik89Si
12
Mar 7, 2005 04:16 PM
littlecivic
Jun 28, 2002 11:23 PM
cyberhide
Jul 5, 2001 12:36 AM
