98 accord CEL. How do I get the code?
Old Jun 15, 2004 | 05:29 AM
b18crx's Avatar
Default 98 accord CEL. How do I get the code?
CEL is on and i know where the blue plug is. since there is only one wire in the blue plug, how do i loop it? do i just turn the ignition on while the paperclip is looped back to the single wire? i've tried this and no code. i need instructions.
thank you.
Old Jun 15, 2004 | 10:15 AM
Oh Crap's Avatar
You would need an OBDII scan tool
Old Jun 15, 2004 | 10:17 AM
b18crx's Avatar
Default Re: (Oh Crap)
the paperclip method won't work? i've seen people do it with obdII itrs. where is the plug on the accords?
The_Todd's Avatar
Farts in the shower
Default Re: (b18crx)
Check your pm's
Old Jun 15, 2004 | 10:20 AM
Oh Crap's Avatar
Yeah on other Hondas you can.. But for some reasons.. You can't on the accord..
this is what ALLDATA says
Old Jun 15, 2004 | 10:24 AM
b18crx's Avatar
Default Re: (VRDrvr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRDrvr &raquo;</TD></TR><TR><TD CLASS="quote">Check your pm's </TD></TR></TABLE>
still cant find the plug.
Old Jun 15, 2004 | 10:25 AM
b18crx's Avatar
so dealer only to find out what the CEL code is huh?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oh Crap &raquo;</TD></TR><TR><TD CLASS="quote">Yeah on other Hondas you can.. But for some reasons.. You can't on the accord..
Old Jun 15, 2004 | 10:39 AM
Oh Crap's Avatar
It doesn't have to be the dealer.. Some indepedant shops will do it for $40 or so if you only want the code.. But first things first check the gas cap.
Old Jun 15, 2004 | 11:14 AM
philadd's Avatar
Autozone does it for FREE...
Old Jun 15, 2004 | 11:16 AM
notoriousB's Avatar
OMG - you certainly CAN read the code with a jumper wire (or a ghetto paper clip!) on a 98 accord! I do it all the time w/ my turbo setup. It's not a blue plug, it's a black 16 pin OBD2 port.
Find the OBDII port - under the dash, to the leftmost side. Place the jumper wire into pins 8 and 13 (counting from the top left to the right (1-8), bottom left to right )9-16)), put the key into the ignition, turn it to ON (don't start) and read your codes from the CEL light. Long blink = 10's digit, short blink = 1's. Very easy.
Old Jun 15, 2004 | 12:48 PM
b18crx's Avatar
Default Re: (notoriousB)
what would i do without this forum?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">OMG - you certainly CAN read the code with a jumper wire (or a ghetto paper clip!) on a 98 accord! I do it all the time w/ my turbo setup. It's not a blue plug, it's a black 16 pin OBD2 port.
Find the OBDII port - under the dash, to the leftmost side. Place the jumper wire into pins 8 and 13 (counting from the top left to the right (1-8), bottom left to right )9-16)), put the key into the ignition, turn it to ON (don't start) and read your codes from the CEL light. Long blink = 10's digit, short blink = 1's. Very easy.</TD></TR></TABLE>
Old Jun 15, 2004 | 01:07 PM
b18crx's Avatar
i found the plug in which your are speaking. it's on the driver's side next to the hood release. i tried the "8" and "13" but nothing happened. 98, lx accord, 4cyl.
Old Jun 15, 2004 | 03:17 PM
notoriousB's Avatar
oh **** I just re-read my post, and the OBD2 connector is not horizontally mounted. it's vertical - D'OH! If you look at it the "long" way, with the bottom being the left side in my description, that's how it's pinned out. I wish I had a diagram. does this make sense?
look at it with the "left" in my description being the side pointing to the hood release and the "top" being the long edge closest to your door.
sorry for the confusion...
Old Jun 15, 2004 | 03:35 PM
Oh Crap's Avatar
Damn don't you love pictures.
Old Jun 15, 2004 | 03:49 PM
notoriousB's Avatar
that's it! says a thousand words... LOL.
Old Jun 15, 2004 | 05:16 PM
b18crx's Avatar
thats really not the problem because the plug pins are numbered as well so you can't get it wrong. the problem is that i followed the instuctions and still no code........the CEL doesnt blink at all.
Old Jun 15, 2004 | 06:10 PM
notoriousB's Avatar
interesting I didn't know they were numbered. you're turning the key all the way to the ON position too (not accessory)?
are you using a piece of wire or just a paper clip? maybe you need to use a wire? (too much resistance on a paper clip?)
I'm just throwing thoughts out, I've read my codes many times this way using a jumper wire so I know it works... and works well.
you're hooking the wire up before turning the key right?
not sure what else to suggest. I've always just put the wire in and turned the key to ON and the codes start flashing...
Old Jun 16, 2004 | 02:00 PM
b18crx's Avatar
couldnt get this accord to replicate your success. maybe autozone has an OBD scanner.
Old Jun 16, 2004 | 06:15 PM
b18crx's Avatar
Default Re: (philadd)
went to autozone. they used the scanning tool but gave no codes. all they were able to tell me was it had to do with exhaust gases, so egr, o2, or cat......great. that much i knew pretty much. ill just have to bite the bullet and pay the damned dealer and pay them to tell me the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">Autozone does it for FREE... </TD></TR></TABLE>
Old Jun 17, 2004 | 08:56 AM
notoriousB's Avatar
if autozone can't pull any code, that's why you couldn't get it w/ the jumper wire trick also. do you have the code right when you start the car? If I'm not mistaken that's the only way you can read the code, is if it's in the ECU on start up...
Old Jun 17, 2004 | 09:05 AM
b18crx's Avatar
autozone pulled the problem just fine. but their scanner is very limited and only gave a generalization of the problem, not the HONDA code but very general. the scanner said "exhaust gases not flowing properly". which could be a code for EGR, o2, or cat.
if autozone can't pull any code, that's why you couldn't get it w/ the jumper wire trick also. do you have the code right when you start the car? If I'm not mistaken that's the only way you can read the code, is if it's in the ECU on start up...</TD></TR></TABLE>
Old Jun 17, 2004 | 10:34 AM
Oh Crap's Avatar
If you have the actual P0xxx or P1xxx code I can define it for you.
Old Jun 17, 2004 | 11:32 AM
b18crx's Avatar
i think i saw a p040 or p0404. pretty sure thats what i saw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oh Crap &raquo;</TD></TR><TR><TD CLASS="quote">If you have the actual P0xxx or P1xxx code I can define it for you.</TD></TR></TABLE>
Old Jun 17, 2004 | 02:03 PM
philadd's Avatar
man.. that sucks... the autozone's here give you both a description AND the actual codes.
Anyway, good luck solving the problem
Old Jun 17, 2004 | 02:26 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18crx &raquo;</TD></TR><TR><TD CLASS="quote">i think i saw a p040 or p0404. pretty sure thats what i saw.
P0401 is a low EGR flow code that is very common. If it's a v6 model with less than 80,000 miles on it, take it to a dealer for a free fix.
