Confused, which MAP sensor do I use? pm6 or pw0? b16 swap, PICS! :)
Old Jun 14, 2004 | 11:51 PM
vitrox's Avatar
Default Confused, which MAP sensor do I use? pm6 or pw0? b16 swap, PICS! :)
wtf do I do with this hose? do I use the pw0 map or the pm6 map that came with my car? Do I cap the hose or what? The hose in question is circled in red, and the pw0 map sensor where the hose goes is circled in red. someone help, there is no spot on the pm6 for this thing.. grrrrrrrrr......
Here is a shot just to show everyone whats done so far.. looks pretty.
Old Jun 15, 2004 | 12:16 AM
Malgerus's Avatar
Default Re: Confused, which MAP sensor do I use? pm6 or pw0? b16 swap, PICS! :) (vitrox)
Looks good man. Don't worry - a MAP sensor is a MAP sensor... sell the B16 one.
Old Jun 15, 2004 | 12:31 AM
vitrox's Avatar
thats what everyone keeps saying.. but wtf does that hose go then?
Old Jun 15, 2004 | 06:32 AM
crx_88_si's Avatar
i'd just plug it up. give me your email (or email me) and I can send you the VTEC Service Manual Suppliment, which shows VAC diagram for b16a JDM motors.
(PDF File)
mike@homemadeturbo.com
Old Jun 15, 2004 | 08:28 AM
vitrox's Avatar
I already have that one bookmarked, thanks, still does anyone know for sure which to use? someone go look at their b16 and see where that hose goes to.
Old Jun 15, 2004 | 08:31 AM
slowpokesi's Avatar
Default Re: (vitrox)
refer to my sig, check the swap guide and thats how i routed my vac lines.
Old Jun 15, 2004 | 09:20 AM
vitrox's Avatar
Default Re: (slowpokesi)
in your picture it shows the pm6 as having that port for the vaccum line, but it doesn't.
Old Jun 15, 2004 | 09:28 AM
rioninja's Avatar
Its real easy. All you need is a single vacuum line going from the purge valve to the manifold. Just remove that double line thing and run a single vacuum line.
Old Jun 15, 2004 | 11:22 AM
slowpokesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vitrox &raquo;</TD></TR><TR><TD CLASS="quote">in your picture it shows the pm6 as having that port for the vaccum line, but it doesn't.</TD></TR></TABLE>
what letter are you talking about there are a couple of vacum lines
Old Jun 15, 2004 | 11:36 AM
vitrox's Avatar
see pictures.
Cian Mcloughlin
May 20, 2013 10:11 AM
Brian Hinson
13
Jun 24, 2006 04:05 PM
ALL MOTOR DA
Jun 8, 2006 02:35 PM
DC 2
Mar 9, 2004 07:00 AM
