will a 1 wire o2 sensor pass smog on a 4 wire ECU???
Old Jun 14, 2004 | 08:58 PM
eg6cusco10pt's Avatar
Default will a 1 wire o2 sensor pass smog on a 4 wire ECU???
I have a 92 CX with 99 EX swap and it has the original engine harness with 1 wire o2 sensor but I'm running a p28 ECU and its reading a 4 wire o2 so I need to know if it will pass smog or how to make it pass smog any helpful information thanks.
Old Jun 14, 2004 | 09:06 PM
devnull's Avatar
Default Re: will a 1 wire o2 sensor pass smog on a 4 wire ECU??? (eg6cusco10pt)
No it will pass smog. Also you will receive the O2 heater sensor CEL. You need to wire up the other 3 wires. It's pretty easy. Search on here for the 4 wire conversion I know that someone has posted the pic before.
Old Jun 14, 2004 | 10:16 PM
Default Re: will a 1 wire o2 sensor pass smog on a 4 wire ECU??? (qi_doy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qi_doy &raquo;</TD></TR><TR><TD CLASS="quote">No it will pass smog. Also you will receive the O2 heater sensor CEL. You need to wire up the other 3 wires. It's pretty easy. Search on here for the 4 wire conversion I know that someone has posted the pic before.</TD></TR></TABLE>i'm a little confused, no it will pass smog or no it won't pass smog???
Old Jun 15, 2004 | 08:24 AM
Joseph Davis's Avatar
You don't need to wire up three wires, you just have to drop switched ignition power (I tap into yel/blk B1, usually) across a 10 ohm 5 watt resistor, and ground it at org/grn A6. The ECU clicks code 41, O2HC, based on whether or not the ECU has any current flowing in at org/grn A6.
I normally chip such setups to ignore O2HC, but you can achieve the same thing for $2 and a few minutes work.
I don't think you have a hope in hell of passing smog with a CEL... but without the car will pass smog if everything is in good running order.
Old Jun 15, 2004 | 08:13 PM
Default Re: will a 1 wire o2 sensor pass smog on a 4 wire ECU??? (J. Davis)
thanks for all replys,to end this topic i'm just gonna try to get a hook up
Old Oct 27, 2011 | 01:05 AM
lek9l's Avatar
Want to know how to convert a 1 wire into 4 wire, here you go:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-wire-vtec-knock-sensor-4-wire-o2-sensor-guide-2991706/
adobospoon
Jul 14, 2008 04:32 PM
greatbiggiants
Jun 7, 2008 04:54 PM
itsalmostfrieday
10
Mar 17, 2007 03:33 PM
robbieshonda
Apr 9, 2004 12:38 PM
trooper0641
Jul 4, 2003 12:59 AM
