b18c1 swap into 91 si hatch.. which dizzy is needed?
Old Jun 14, 2004 | 08:39 PM
typeeg's Avatar
Default b18c1 swap into 91 si hatch.. which dizzy is needed?
I believe its the b16a obd0 jdm dizzy but I am not for sure.
Will any other obd0 dizzy work? Maybe from 92 gsr OR 90-93 LS?
Old Jun 14, 2004 | 09:01 PM
EF_LSVtec's Avatar
Default Re: b18c1 swap into 91 si hatch.. which dizzy is needed? (StockEG9)
B16A obd0 dizzy is perfect...90-93 LS will work too but you have to cut one of the mounting "ears" to fit (can only use 2 bolts as suppose to 3).
Old Jun 15, 2004 | 03:47 AM
crxgsr91's Avatar
Default Re: b18c1 swap into 91 si hatch.. which dizzy is needed? (EF_LSVtec)
B16 OBD-0. Do not use an LS, it was not ment to rev that high and may misfire at high rpms.
Old Jun 15, 2004 | 07:19 AM
typeeg's Avatar
Default Re: b18c1 swap into 91 si hatch.. which dizzy is needed? (crxgsr91)
If you need to replace the cap, rotor, and coil etc.. what do you tell the person at the parts store as far as which car it is for if I have obd0 b16a dizzy?
Old Jun 15, 2004 | 07:43 AM
FULL-RACE EP3's Avatar
i'm pretty sure 90-91 teg cap and rotor would fit.
I had a non-obd b16 on my gsr motor and when that took a dump I used a brand new non-obd LS dist. with no problems whatsoever.
Old Jun 15, 2004 | 07:47 AM
crx_88_si's Avatar
http://www.tunertoys.com
Old Jun 15, 2004 | 02:13 PM
typeeg's Avatar
Default Re: b18c1 swap into 91 si hatch.. which dizzy is needed? (Pooptooth)
If i were to just replace some of the parts such as cap, coil, stuff like that WHICH car do I tell the person at the auto store the motor came from since there was never an obd0 b16a in america? Is it the same as obd1 or obd2 b16a distributor as far as whats inside? WHat makes the obd1 or 2 not fit on a 1991 civic si?
Old Jun 15, 2004 | 02:26 PM
eda6's Avatar
I'm using 94 delsol vtec wires and plugs
rotor/cap any DA integra
88 hatch obd0 w/b16 my setup
Old Jun 15, 2004 | 02:54 PM
rioninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgsr91 &raquo;</TD></TR><TR><TD CLASS="quote">B16 OBD-0. Do not use an LS, it was not ment to rev that high and may misfire at high rpms.</TD></TR></TABLE>
That couldnt be farther from correct. All the obd-0 multipoint distributors have the same internals. That includes the stock crx/civic si and hfs.
Old Jun 15, 2004 | 02:56 PM
typeeg's Avatar
Default Re: b18c1 swap into 91 si hatch.. which dizzy is needed? (rioninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">
That couldnt be farther from correct. All the obd-0 multipoint distributors have the same internals. That includes the stock crx/civic si and hfs.</TD></TR></TABLE>
So I could use one from a DA? What modifications do I need to make to do this on a b18c1 in 1991 civic si?
And I guess you kind of answered my other question as to which parts I can swap out into my existing distributor... In other words I could just ask for cap and rotor coil and etc from parts store for ANY obd0 usdm motor correct?
Old Jun 15, 2004 | 03:37 PM
Rywire's Avatar
I have a mint conditioned b16a obd0 distributor for sale, near new cap and rotor. $150.00 plus 10 for shipping. Ryan
Old Jun 15, 2004 | 06:46 PM
rioninja's Avatar
Like was posted above, the LS distributor will work, but you will have to modify/rig it to fit. The only bolt on is the obd-0 b16a distributor. I picked one up a few months ago for $25 and swapped in some DA internals i had laying around. The only problem is that obd0 distributors are sometimes a bitch to work on. They are put together with hollow tip torx bits that love to snap off.
Old Jun 15, 2004 | 06:54 PM
StorminMatt's Avatar
B18C1 + 1G JDM B16A ECU = Halfass.
Old Jun 15, 2004 | 07:04 PM
typeeg's Avatar
Default Re: b18c1 swap into 91 si hatch.. which dizzy is needed? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">B18C1 + 1G JDM B16A ECU = Halfass.</TD></TR></TABLE>
Could you explain?
Old Jun 15, 2004 | 08:05 PM
Rywire's Avatar
Its because its obd0, and it could run obd1. Either is fine in my opinion. Ryan
Old Jun 15, 2004 | 08:51 PM
bossman032's Avatar
OBD1 motor being ran with obd0 dizzy..
obd0 dizzy are not really good they tend to have problems
but whatever works
Old Jun 16, 2004 | 06:09 AM
typeeg's Avatar
Default Re: b18c1 swap into 91 si hatch.. which dizzy is needed? (bossman032)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bossman032 &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 motor being ran with obd0 dizzy..
but whatever works </TD></TR></TABLE>
But I thought if you have OBD0 wiring such as my 91 civic si, You have to use an obd0 distributor? Isn't this why the only one that bolts on for my year car with b18c1 is the 1st gen b16a dizzy?
Old Jun 16, 2004 | 06:14 AM
1st-hybrid's Avatar
You can always convert to obd1 and use the b18c distributor. This way everything is the way it should be
Check the link in my sig for conversion harness info
Old Jun 16, 2004 | 06:20 AM
typeeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">B16A obd0 dizzy is perfect...90-93 LS will work too but you have to cut one of the mounting "ears" to fit (can only use 2 bolts as suppose to 3).</TD></TR></TABLE>
can you explain to me a bit more in detail about how you modify to make it fit? Not understanding the "ears" part
Old Jun 16, 2004 | 07:57 AM
EF_LSVtec's Avatar
Think of the dizzy as your head, you have 2 ears that stick out, that's where the dizzy is bolted down. On the otherhand, a dizzy have 3 ears, 1 bolt on each ear. If you try to use an LS dizzy, you will find out that one of the ears will hit the vtec solenoid so you must cut it off and bolt it down using only 2 bolts.
* B16A non obd distributor have the same internals and cap and rotor as all non obd LS distributors.
* Only downside in using a modified LS distributor is you can only move it so much therefore limiting your timing adjustment capabilities...
* I also have a B16a (non obd) dizzy for sale, $150 shipped, in case you're interested. I'm sure you can get em cheaper anywhere else too...cheapest I found is about $130 shipped here on HT Classifieds
Good luck
Old Jun 16, 2004 | 10:00 AM
Rywire's Avatar
Good analogy on the head thing, lol. Hey, have you played Poppy lately? See ya around. Ryan
Old Jun 16, 2004 | 10:50 AM
EF_LSVtec's Avatar
Default Re: b18c1 swap into 91 si hatch.. which dizzy is needed? (droppedcrxsi)
I was suppose to play last Sunday, but I had to take my family to Yosemite for the weekend...My friend has a tee time on 5th of July, 8am, maybe I'll see you then...
Old Jun 16, 2004 | 12:44 PM
Cnote's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 &raquo;</TD></TR><TR><TD CLASS="quote">I believe its the b16a obd0 jdm dizzy but I am not for sure.
Will any other obd0 dizzy work? Maybe from 92 gsr OR 90-93 LS?</TD></TR></TABLE>
obd0 dizzy will work.
B16A obd0 preffered and best option
B18A obd0 not recommended
odb0 on B18C1(stock form) does not make the full range of power from the motor. Would recommend getting obd1 ECU and electronics due to the butterflies and other issues.
Old Jun 16, 2004 | 03:06 PM
typeeg's Avatar
Default Re: b18c1 swap into 91 si hatch.. which dizzy is needed? (Cnote)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cnote &raquo;</TD></TR><TR><TD CLASS="quote">
odb0 on B18C1(stock form) does not make the full range of power from the motor. Would recommend getting obd1 ECU and electronics due to the butterflies and other issues.</TD></TR></TABLE>
Are you sure about this comment? I have a zydne chipped pm6 ecu which uses b18c1 mappings and dual butterflies.
Old Jun 16, 2004 | 03:42 PM
crxgsr91's Avatar
You don't have to believe me if you don't want to, but I learned the hard way.
The dumb a$$ mechanic who installed my engine used my old distributor and converted the engine to OBD-0. After running a 15.9 I went to the shop pissed off and demanded they fix it after two dyno runs of 120whp we noticed the dyno chart was skipping around and asked what that ment. They said it was a high rpm misfire after changing to an OBD-0 B16 distributor that fixed that problem.
