Coil Overs vs. Lowering Springs
Regaurdless you will have to replace the shocks to have a smooth ride. I think name brand lowering springs would give you a better ride then coil overs but the coil overs are prolly not that much worse of a ride but give you alot more adjustability.
Don't expect to "slam" your car and maintain a smooth ride. I have a 1.8" drop on Tokico Illumina's and Tokico Springs and its a smooth as stock. As for coilovers i had coilovers on stock struts and the ride was horrible. It was ok for the first 3 months but after that the car bounced like hell. With coilovers what you gain in adjustability you loose in comfort. With a coilover you don't get nearly as much spring as a lowering spring. I mean you are replacing spring with a threaded metal sleeve, so the spring is shorter.
GsR HtCh
12
Jul 25, 2002 05:39 AM
