91 Accord LX Auto questions
Old Jun 14, 2004 | 07:04 PM
hacman's Avatar
Default 91 Accord LX Auto questions
Howdy. I came in here from a search regarding tranny stuff on the 4th gen accords, but figured i'd ask the folks that know the best about this honda.
I'm looking to buy this 91 Accord LX Auto. I need something reliable and cheap that can make at least a monthly 750 mile round trip drive.
The only problem i found thus far is (sadly) the tranny. But i don't know what to think:
it's an AT with the Sport shift option. in first, it'll run up to about 3000-3500 rpms before shifting, regardless of throttle position. all other shifts seem fine. I've read about the "positive shift" thing, and i'm also reading about the fluid changes. i don't know the service history of this vehicle. The sister of the owner is selling it (fiancee of a friend, so i trust her).
here's the specs:
1991 Accord LX 4dr Auto
PW/PL (power to locks don't work)
AC (can't tell if it's cold though)
174,000 miles (this scares me)
$1500
think that's a fair price? What else should i look for other than the tranny? CV Joints i'll check out in the morning. i have the car all week.
Thanks!
hac
Old Jun 14, 2004 | 07:30 PM
91wagon's Avatar
Default Re: 91 Accord LX Auto questions (hacman)
Sounds pretty good to me, even if you get just a few years out of it. Say you get it to go to 210,000, that is 48 months or 4 years at 750 miles a month.
Old Jun 14, 2004 | 07:46 PM
hacman's Avatar
Default Re: 91 Accord LX Auto questions (91wagon)
what about the tranny? should i worry or just service it?
Old Jun 14, 2004 | 08:08 PM
alb_accord's Avatar
well if u drive it normaly it should shift about about
1 gear >>> 2700rpm
2 gear >>> 2800rpm
this is on normal driving conditions.
then u should do another test
pull a little hard. make sure the tranny shifts over the 3500rpm on first second and third gears. if u see any jump between these gears then the tranny is going bad.
check the tranny fluid. smell it. if it smells bad then the tranny its on his way down.
but the tranny is the easy part to change in the car.
make sure the engine runs good and doesn't burn any oil. get a compresion test and check for oil leaks around the engine. check the crank shaft pulley.
Old Jun 15, 2004 | 06:57 AM
Justin Klemgold's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hacman &raquo;</TD></TR><TR><TD CLASS="quote">174,000 miles (this scares me)
Why does that scare you? Do you own a domestic or something????
I have 248k on my 91 Accord and in two weeks, I'm taking it on a 1500 mile round trip vacation. I have no worries.
175 is a baby....there's a guy on this board with over 340k on his accord and it's still running perfectly....
Old Jun 15, 2004 | 08:10 AM
alb_accord's Avatar
most of them are high way driven.
my engine on my accord died at 140k and the tranny died at 145k. i had to swap both of them.
that is why the guy is scared.
Old Jun 15, 2004 | 09:04 AM
hacman's Avatar
Default Re: (alb_accord)
exactly alb...
i've never owned a car with that high of mileage. that's why i'm a tad worried
Old Jun 15, 2004 | 10:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alb_accord &raquo;</TD></TR><TR><TD CLASS="quote">most of them are high way driven.
that is why the guy is scared.</TD></TR></TABLE>
Your car was obviously not properly maintained...most of my miles are highway miles as well...it runs like a champ....why? Because it was properly maintained. You can't abuse a car and expect it to treat you well...
Old Jun 15, 2004 | 10:32 AM
hacman's Avatar
Default Re: (Justin Klemgold)
that's another worry of mine. 175,000 miles, no idea of the maintenance history. ;(
also, i noticed a small puddle of oil under the car. it had sat there since march though.
and timing belt? my school of thought with those was with a mazda i owned years ago, and we replaced that at 60,000 i think.
Old Jun 15, 2004 | 12:13 PM
hacman's Avatar
Default Re: (hacman)
findings:
okay, the shop downstairs found that oil is leaking (was 3/4 quart low)
tranny fluid leaking (was 3 quarts low)
brake fluid was a little low but no visible leaks
exhaust needs to be replaced from the cat back
bushings here and there
a motor mount was a little tweaked somewhere
as for the drive afterwards, on normal condition, tranny shifted from 1 to 2 at 3200. 2-3 at 2800
heavy accel - 1-2 was 4200 or so
2-3 was 3800 or so
shop didn't notice anything with the tranny fluid about smell. tech said it's a good deal, and as long as i watch the fluids i'll be fine.
thoughts?
Old Jun 15, 2004 | 04:56 PM
3 quarts low on tranny fluid eh? I don't know about Accords, but my Integra holds 2.5 quarts of tranny fluid...sounds like it was almost dry.
Old Jun 15, 2004 | 07:14 PM
hondadude's Avatar
Default Re: 91 Accord LX Auto; week long test drive?!?
The shift problem COULD be the throttle cable has been tightened to bump up idle and that will mess up the trans pressure cable setting that goes to the transmission pressure lever from the throttle body
Old Jun 16, 2004 | 07:02 AM
alb_accord's Avatar
well dude my car was clean as hell. the car was maintaned. and it was owned only by two people before me. the last one was a woman. she bought the car at the same place where she took it bac after 6 years.
my problem was that it keept braking the exaust vavle on #1 piston. it did it 3 times. which means the bottom of that #1 piston probably was big time fucked.
now my first accord that was a different story. that one lasted forever.
by the way. first gear shifting at 3200 rpm that is bad man. that should shift at 2700rpm. so probably something wrong with the tranny(personal experience)
Old Jun 16, 2004 | 03:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alb_accord &raquo;</TD></TR><TR><TD CLASS="quote">by the way. first gear shifting at 3200 rpm that is bad man. that should shift at 2700rpm. so probably something wrong with the tranny(personal experience)
It depends on throttle position.
Old Jun 16, 2004 | 04:03 PM
accordmurf's Avatar
[QUOTE=alb_accord]well dude my car was clean as hell. the car was maintaned. and it was owned only by two people before me. the last one was a woman. she bought the car at the same place where she took it bac after 6 years.
nuff said....just kidding
BlackEJ8
May 2, 2007 10:21 PM
wyldbil
Jun 2, 2004 06:35 PM
xhopesfall20
Sep 22, 2003 09:31 PM
cyrixvsp2
Dec 20, 2002 09:29 AM
