My Distributor is apparently binding the intake cam...
Old Jun 14, 2004 | 05:41 PM
*Boostwerks*'s Avatar
Default My Distributor is apparently binding the intake cam...
I have a "brand new" distributer that I installed into my Built 95 B18C1, that was just too long. When its bolted in, it binds the cam against the caps.
We found this out when we tried to start it for the first time, and the timing belt just jumped the cam gear.
Is it just machined wrong or do I not have the correct one? It pluged in fine, and the bolt pattern is perfect.
I've never run into a problem like this before...
Old Jun 14, 2004 | 08:40 PM
turbohondask's Avatar
Default Re: My Distributor is apparently binding the intake cam... (Bryson)
is the dizzy shaft 180 degrees out of place?
Old Jun 14, 2004 | 09:33 PM
StyleTEG's Avatar
Default Re: My Distributor is apparently binding the intake cam... (turbohondask)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohondask &raquo;</TD></TR><TR><TD CLASS="quote">is the dizzy shaft 180 degrees out of place?</TD></TR></TABLE>
Thats what I would check.
Had a friend help me put my head back on once, he bolted it in 180 degree's out of place. Went to tension the belt and many teeth it jumped.
Old Jun 15, 2004 | 05:15 AM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Did u have to kinda force the dizzy key in the cam slot..?..if so then i definatley agree with the above..
Old Jun 15, 2004 | 11:03 AM
Default Re: My Distributor is apparently binding the intake cam... (bruceleeroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruceleeroy &raquo;</TD></TR><TR><TD CLASS="quote">Did u have to kinda force the dizzy key in the cam slot..?..if so then i definatley agree with the above..</TD></TR></TABLE>
this almost always true,
Old Jun 15, 2004 | 03:00 PM
paybac4223's Avatar
i thought the way that the dizzys were made you cant install them backwards???
Old Jun 15, 2004 | 03:10 PM
SYD's Avatar
SYD
Default Re: My Distributor is apparently binding the intake cam... (paybac4223)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paybac4223 &raquo;</TD></TR><TR><TD CLASS="quote">i thought the way that the dizzys were made you cant install them backwards???</TD></TR></TABLE>
it can be done if forced on..some need less force then others i guess its all in the machining process..but ive seen people do it so many times..
Old Jun 15, 2004 | 04:03 PM
dfoxengr's Avatar
yes the dist is 180 off. i did this once and jumped a few teeth.
Old Jun 15, 2004 | 10:25 PM
Yup...that was exactly my problem...
However, according to my helms the little line on the distributer key is supposed to be aligned with the line on the distributer case. However, it is on the opposite side when it fits?
Am I just reading the helms wrong?
Old Jun 15, 2004 | 11:12 PM
XDEep's Avatar
Default Re: (Bryson)
just to be sure you can open the cap and make sure the rotor is in the vicinity of the #1 terminal, with your #1 piston at TDC of course.
Old Jun 16, 2004 | 08:01 AM
dfoxengr's Avatar
Default Re: (XDEep)
dont listen to the helms for this. just put it where it slides in and let it be that.
Old Jun 18, 2004 | 11:48 PM
Default Re: (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">dont listen to the helms for this. just put it where it slides in and let it be that. </TD></TR></TABLE>
Well I guess I can't trust the book for everything...
I now have 2 bent intake valves on #4...
compression (1-4) 130, 130, 125, 0
The heads now at the machine shop. I hate how little mistakes like this can end up being very costly, and time consuming. stupid cars...
Old Jun 19, 2004 | 12:02 AM
SYD's Avatar
SYD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">
The heads now at the machine shop. I hate how little mistakes like this can end up being very costly, and time consuming. stupid cars... </TD></TR></TABLE>
yup its the little stuff that pisses me off the most....like bending valves because u jumped timing from a little nut falling in the cover....
good luck
Old Jun 19, 2004 | 05:57 AM
XDEep's Avatar
damn sorry. so do you know exactly what the problem was and why it happened now?
Old Jun 19, 2004 | 08:12 AM
91civicDXdude's Avatar
dont call the car stupid because YOU put the distributor in backwards.. there is an obvious difference to the distributor sliding right in and you having to force it into place.. I'd call the operator/mechanic stupid on this one...
Craigvining
Nov 6, 2017 06:32 AM
crazyguy
Jan 30, 2008 07:52 AM
B18C-Hatch
Sep 6, 2006 10:06 AM
Aquafina
10
Nov 20, 2005 01:27 PM
2000fbp
Aug 27, 2003 09:19 PM
