Power Slot Rotors with free Shipping and 5% off
Heat is the primary cause of ineffective brakes due to fade. There is actually a “boundary layer” of gases that builds up between the pad and rotor surface which inhibits performance. Here’s where Power Slot rotors make a big difference. The exclusive Vac-U-Slots machined into the rotor “wipes” brake pads clean, evacuates gases, and sheds heat. A combination of a “high performance pad” and Power Slot rotors will provide superior reliable braking for virtually all automotive and truck applications, with an upgrade to larger diameter rotors and bigger calipers typically only needed for the most severe competition applications.
Power Slot rotors are manufactured to the highest tolerances keeping SAFETY and quality our number one priority. Slotting, unlike drilling, doesn’t compromise the structural integrity of the rotor. When you drill a rotor you weaken it and cause stress points that can lead to cracking and ultimately failure. Also, drilled rotors lose considerable surface area compared to slotted rotors which means less active braking area for pad to rotor contact.
Power Slot rotors are made using the highest quality Original Equipment replacement blanks. Competitors will sacrifice quality by using inexpensive off-shore castings. Typically these are made of inferior porous material and often have less cooling fins than their OE counterpart. These fins also serve to reinforce the rotor and guard against warpage. Power Slot rotors always meet and/or exceed all OE specifications. It’s also important to know that the exclusive Vac-U-Slot is tapered to enhance evacuation of heat and gases. All machining is done in house to Power Performance Group’s application specific tolerances to ensure optimum quality control.
The final touch is a military-spec cadmium plating that gives Power Slot rotors their bright silver finish and protects the rotor from the elements. This eliminates rusty rotor syndrome and enhances the look of custom wheels.
Click here to order and for full application list:
http://www.prostreetonline.com...otors
Use coupon code PSO5D for 5% off!
Modified by prostreetonline at 9:59 AM 6/21/2004
prostreetonline
Jun 8, 2005 09:52 PM
prostreetonline
17
May 14, 2005 03:28 PM
4doorex
22
Jan 22, 2004 06:53 AM
