cutting valve cover for cams tuning.....
Old Jun 14, 2004 | 04:15 PM
ef93si's Avatar
Default cutting valve cover for cams tuning.....
i've seen the H22's that have the oval/moon style cut for the tunable cams....i was thinking of cutting my h23 cover for that, but is it just cutting? other things involved? anyone done this?
Old Jun 14, 2004 | 04:27 PM
hOndafienD 04's Avatar
i was also thinking about doing this....can i just cut it with the wiz wheel?
btw instant message me @ hondafiend04 or email me @ hondafiend04@aol.com about the headers, price, brand, etc....thanx
Old Jun 14, 2004 | 06:50 PM
ef93si's Avatar
hey man,
headers are sold, sorry forgot to change the price. yea, anyone done this?
i would just use a dremel?
Old Jun 14, 2004 | 06:54 PM
dammit! lol.....umm i dunnoif a dremel would work, but it might....im about to just use a wiz wheel....when i do my timing belt...
Old Jun 14, 2004 | 09:33 PM
Hawkze_2.3's Avatar
Default Re: cutting valve cover for cams tuning..... (ef93si)
I don't see why you couldn't use a Dremel and some patience...
Old Jun 15, 2004 | 02:01 AM
del_parker's Avatar
a dremel(SLOW!), angle grinder, torch(not pretty), or a plasma cutter.
Old Jun 15, 2004 | 04:13 AM
ef93si's Avatar
any special way to do it? or just trace it out and then go at it?
Old Jun 15, 2004 | 05:50 AM
dc5r2002's Avatar
Default Re: (ef93si)
i just did this on my h23 and had the moon cut come out perfect, the way to do it is with a holesaw, if you dont know what that is its a drill bit in the center with a saw around the bit the size of the cam gear
well since we todd is down here is a link to what i am talking about
http://search.ebay.com/holesaw...omZR8
Old Jun 15, 2004 | 07:22 AM
intresting tool...got pics of the valve cover???
Old Jun 15, 2004 | 07:26 AM
killa_lude's Avatar
Default Re: (hOndafienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">dammit! lol.....umm i dunnoif a dremel would work, but it might....im about to just use a wiz wheel....when i do my timing belt...</TD></TR></TABLE>
i used a dremel, and it worked fine.
Old Jun 15, 2004 | 07:27 AM
jdm22vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">got pics of the valve cover???</TD></TR></TABLE>
I cheated and bought mine off ebay
I'm sure a dremel or a whiz wheel would work fine as long as you have the patience.
well i don't have one anyway.....i think im gonna use the wiz wheel...
Old Jun 15, 2004 | 07:28 AM
Default Re: (jdm22vtec)
niiiice....how much did you pay?
Old Jun 15, 2004 | 09:32 AM
Speedra500's Avatar
you can find something circular about the same diameter and trace out the area to be cut away, and instead of using a saw to cut it out, you can drill lots of holes near the edge of your line and after you do that just break the small links between them and buy an sanding attachment for your drill (could use a dremmel but it would take a long time) and just sand it smooth. Here is a picture of mine that i did, I still have to work on it a little, but it came out pretty good for the most part the first time, oh yea on my valvecover 93 lude the ground was in the area that I had to cut out, so i uncrimped the wire off the stock wire(pain in the ***) because it was too short now and I got some of that blue 4 ga wire I had laying around and crimped it on there and grounded it at the powersteering line holder bolt
If I had to do this over again, I would try and buy some connects instead of taking off the stock ones
Old Jun 16, 2004 | 03:45 AM
dc5r2002's Avatar
Default Re: (Speedra500)
look dude buy a the hole saw like i said above they make such a nicer cut in a 1/8 of the time and its almost impossible to mess it up unless u measure wrong
i will post the pics after lunch time here around 12:30 they should be up, i gotta go get a camera over lunch
Old Jun 16, 2004 | 06:34 AM
Jason kiDD's Avatar
Default Re: (Pulp Fiction)
What size blade did you use to get the job done?!
Old Jun 16, 2004 | 09:17 AM
dc5r2002's Avatar
Default Re: (Jason kiDD)
off the car in this one
and on it in these two
Modified by Pulp Fiction at 1:48 PM 6/16/2004
Cho0se
Sep 3, 2018 09:36 AM
snobordboy
Apr 26, 2007 09:50 PM
Slomies
Mar 24, 2006 12:34 PM
AndyD
Dec 1, 2002 11:06 AM
