new shiz for da r
Old Jun 14, 2004 | 04:08 PM
marko_think's Avatar
Default new shiz for da r
got my new rotors and pads for the "r"
Old Jun 14, 2004 | 04:10 PM
Outkast_CL9's Avatar
Default Re: new shiz for da r (marko_think)
Nice...I need new brakes for my R...
Old Jun 14, 2004 | 04:17 PM
ITR#JohnBasedow's Avatar
gnarly shiz
Old Jun 14, 2004 | 04:19 PM
white rocket's Avatar
How much $$$?
Looks nice
Old Jun 14, 2004 | 04:31 PM
TheNasty0ne's Avatar
Default Re: new shiz for da r (white rocket)
Write up a "How to"
Old Jun 14, 2004 | 04:34 PM
Dr Pooface's Avatar
Default Re: new shiz for da r (IncrediVTec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IncrediVTec &raquo;</TD></TR><TR><TD CLASS="quote">Write up a "How to"</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=157429
Old Jun 14, 2004 | 04:42 PM
ZygSpeed's Avatar
Default Re: new shiz for da r (Dr Pooface)
Where's that classic pic of "D" hammering a rotor portion to get it off the hub?
Old Jun 14, 2004 | 04:45 PM
.RJ's Avatar
.RJ
Default Re: new shiz for da r (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Where's that classic pic of "D" hammering a rotor portion to get it off the hub? </TD></TR></TABLE>
Haha.
A pair of 10x1.25 bolts would have avoided all that anger
Old Jun 14, 2004 | 04:48 PM
ZygSpeed's Avatar
Default Re: new shiz for da r (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">A pair of 10x1.25 bolts would have avoided all that anger </TD></TR></TABLE>
I do believe that didn't work ...
Old Jun 14, 2004 | 04:50 PM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">I do believe that didn't work ... </TD></TR></TABLE>
Now thats something I'd like to see!
Old Jun 14, 2004 | 04:54 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Now thats something I'd like to see! </TD></TR></TABLE>
Pittsburgh (i.e., salt laden winter roads) are hell on metal components.
Take a look at my 97 some day ... even though its from just across the PA-Ohio line.
Old Jun 14, 2004 | 05:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=157429</TD></TR></TABLE>
Thanks but I want to know how to do the rotors
Old Jun 14, 2004 | 05:02 PM
.RJ's Avatar
.RJ
I've used the "2 bolt" method to pull rotors off the hub before, and it hasnt failed me. On my 91 the hats were rusted/frozen to the hub and the hats cracked when they popped off!
After I drilled out those dayum screws, of course...
Old Jun 14, 2004 | 05:06 PM
ZygSpeed's Avatar
I don't believe in "never" and "always"!
Old Jun 14, 2004 | 05:20 PM
Vitmn R's Avatar
NICE, Brakes are a good thing!!!
Kevin
Old Jun 14, 2004 | 06:35 PM
Dr Pooface's Avatar
Thanks but I want to know how to do the rotors</TD></TR></TABLE>
Remove the two phillips screws on the rotor, take the two bolts holding the caliper on (17mm I believe), caliper lifts up and rotor falls off.
Old Jun 14, 2004 | 06:47 PM
leboeuf45's Avatar
i am also getting ready for the itr expo and i ordered powerstop rotors and they suggested axxis metal masters for the front and rear. What are those that u have for the front??
Old Jun 14, 2004 | 08:18 PM
boszyen's Avatar
is that a kangaroo I see on the picture?
Old Jun 14, 2004 | 08:26 PM
Rob :190:'s Avatar
wow, rotors, and pads. well at least you're excited
Old Jun 14, 2004 | 08:56 PM
ek4hatch's Avatar
Default Re: new shiz for da r (Rob :190:)
Old Jun 14, 2004 | 09:01 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob :190: &raquo;</TD></TR><TR><TD CLASS="quote">wow, rotors, and pads. well at least you're excited</TD></TR></TABLE>
They're shiny!
Old Jun 14, 2004 | 09:41 PM
Default Re: new shiz for da r (leboeuf11)
axxis metal masters for the front and axxis delux plus (organic) for the rear.
the axxis ultimates are ceramic.
ceramic pads + brembo blanks + itr=
Old Jun 16, 2004 | 08:33 AM
leboeuf45's Avatar
those phillip screws are a bitch to take out any certain trick?
Old Jun 16, 2004 | 08:35 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leboeuf11 &raquo;</TD></TR><TR><TD CLASS="quote">those phillip screws are a bitch to take out any certain trick? </TD></TR></TABLE>
Impact driver + BFH
There's no other way to do it, other than a drill.
Old Jun 16, 2004 | 09:57 AM
kruthles's Avatar
I used a snap-on screwdriver becuase it had a hex-head on the shaft.
I sprayed it with a ton of lube, put the screwdriver in smacked the hell out of it with a hammer, then had a buddy push the screwdriver in while I had an open-end wrench on the screwdriver to rotate it. screws came out really easy after that
make sure your using a phillips #3 or you get to play with the drill
or like RJ says use an impact driver.
allmost the same setup as mine (axxis ultmates + auto z0ne rotors)
