interchange cam caps
Old Jun 14, 2004 | 03:37 PM
servion's Avatar
Default interchange cam caps
I'm replacing my GSR head with a b16a (2nd gen) head. The head tha tI'm thinking of buying does not have the cam caps. Could I use my GSR ones? Will they fit and oil alright?
Old Jun 14, 2004 | 06:47 PM
servion's Avatar
Default Re: interchange cam caps (servion)
anyone?
Old Jun 14, 2004 | 07:26 PM
HEAD's Avatar
you could use them but your going to have to get them line honed or you could have problems with cam journal wear.
Old Jun 15, 2004 | 05:16 AM
servion's Avatar
Default Re: interchange cam caps (HEAD)
Is this 100% going to be needed? Can I perhaps get lucky and find a set that will work?
I found some OBDII b16 cam cap that I can use... but they're from a different head. Can I visually tell if there will be an issue by placing them on the head and looking in the holes to see if everything lines up? Should I use some plastiguage to check the clearances with the cam installed?
Old Jun 16, 2004 | 11:49 AM
HEAD's Avatar
I am a safe then sorry kind of person, It's $200 to get the caps honed VS $$ for a neww head and cams if they get chewed up. Anything is possible.
jonslam
Mar 7, 2016 11:26 AM
Muckman
Sep 11, 2011 04:58 PM
crispy93
Mar 8, 2007 07:17 PM
shoryuuu
Sep 28, 2006 04:07 AM
