JDM D15b into 90sihatch ecu ?
I just ordered a jdm d15b and i was wondering if i order the ecu, what else will i need to get, would i need get a conversion harness, and what would it be called, would it be a
(http://www.jdmshit.com/ecu/index.html additional hardware)
OBD-0 --> OBD-1 (88-91 cars)
$119 shipped
Brand New Item w/Piggy-Back Harness, Includes Complete Conversion Instructions For OBD-0 to OBD-1
or would it be better for me to get and MSD RPM Activated Switch for the vtec and use my stock si ecu?
$119 shipped
http://www.jkobdconversionharness.com/
^ He sells OBD0 to OBD1 harness
What ECU will you be running?
i'm not sure about the po8 but most obd1 conversions run the p28 ecu. i got a one wire ecu from zdyne allowing me to remain obd0 and only had to run one wire to the vtec solenoid. there is a thread with a pic of how the dist. needs to be mounted i'll see if i can find it.
the thread with the pic is attached to the post at the bottom.
https://honda-tech.com/zerothread?id=882370
it may not be the cheapest way, but me and my buddies arnt too familiar with swaps we are brand new to it, but we want to go with the most simple way, so i ordered the jdm d15b motor, and the p08 ecu that is used to run that motor in the civic vti, so now i am going to order the obd0 to obd1 conversion harness for that ecu, now does anyone think that i should order any other parts or accessories? and will that make the swap complete. (my car is 1990 civic si)
the things you have will make the swap complete, might want to look into some motor mount inserts, for the 14 year old car, but you have everything there that you need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi »</TD></TR><TR><TD CLASS="quote">the things you have will make the swap complete, might want to look into some motor mount inserts, for the 14 year old car, but you have everything there that you need.</TD></TR></TABLE>
sorry for thread jack im doing the same swap what kinda mount inserts are good to get? there usually what around 30-50bux?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIhatch90 »</TD></TR><TR><TD CLASS="quote">now does anyone think that i should order any other parts or accessories? and will that make the swap complete. (my car is 1990 civic si)</TD></TR></TABLE>
Timing belt
Water pump
Alternator belt
Thermostat
I've got a D15B and I am doing my swap hopefully this weekend. I bought all the above items w/ the following:
ACT clutch
Flyhweel
Header
Intake
Timing belt
Water pump
Alternator belt
Thermostat
ACT clutch
Flyhweel
Header
Intake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ba4 »</TD></TR><TR><TD CLASS="quote">
sorry for thread jack im doing the same swap what kinda mount inserts are good to get? there usually what around 30-50bux?</TD></TR></TABLE>
Energy Suspensions or Suspension Techniques
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pisetup »</TD></TR><TR><TD CLASS="quote">
Energy Suspensions or Suspension Techniques</TD></TR></TABLE>
i heard someone saying one of the mounts are a bitch to line up or something? is that true or all stock mounts shoudl work?
let me restate. i swapped a z6 into my 91 and in researching found that i had to take that bracket off of my old b2 and put it on the z6 and i had no problems. the bracket that i took off the z6 was angled differently. so i used the bracket off of the 91 motor and it lined right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter »</TD></TR><TR><TD CLASS="quote">let me restate. i swapped a z6 into my 91 and in researching found that i had to take that bracket off of my old b2 and put it on the z6 and i had no problems. the bracket that i took off the z6 was angled differently. so i used the bracket off of the 91 motor and it lined right up.</TD></TR></TABLE>
I had to do the same thing. Its the bracket that connects the Mount to the motor the one in between. Once you put your old one on there will be no problems with lining it up.
