graphite .. turned out great!..
Old Jun 14, 2004 | 02:11 PM
redlinetuning's Avatar
Default graphite .. turned out great!..
Thanks to everyone who helped from selecting the paint to painting the wheels.
Charlie, Chia, Pong, Steve, & Chia's dad for letting me use the garage.
Chia holding the wheel
I will take some pictures.. hopefully tonight after I wash her.
thanks for looking
one last one..
Charlie in my side-view to Wis...
EDIT:
Stuff to get:
Scuffing pad
brush or toothbrush will work
sandpaper 180, 600, 1000, 2000 grit
Aircraft Paint remover(2-3 cans)
Duplicolor gray sandable primer(2), basecoat of choice(3), and clear coat(2)
spray handle (makes painting a lot easier)
use the remover and spray it over the wheel and let it sit for about 5 minutes. When the paint starts to wrinkle take a brush and scrub. repeat as needed. rinse off with water and repeat as needed.
use the scuffing pad and sandpaper (180) grit to remove any blemishes and then using the 500 grit, sand the wheel down to your liking. rinse with water and repeat as needed them dry them off. (overnight)
just let out the air enough so you can press the sidewalls in to get the index cards in between the tire and the wheel. tape up the valve stem.
start with thin coats of the primer and sand as needed. repeat as needed. basecoat, then clear coat. let the clear dry and using 2000 grit and lots of water, wetsand and buff as needed.
I didn't wetsand mine and buff, but they look great.
Modified by redlinetuning at 5:14 PM 6/21/2004
Old Jun 14, 2004 | 02:18 PM
XxSOHCDriVerxX's Avatar
Default Re: graphite .. turned out great!.. (redlinetuning)
Looks like it turned out nice
Good Job on the paint
Old Jun 14, 2004 | 02:22 PM
Phil DeVtec's Avatar
turned out pretty good! good choice on the color.
Old Jun 14, 2004 | 02:56 PM
amy's Avatar
amy
nice color choice
Old Jun 14, 2004 | 02:57 PM
wowpaw's Avatar
Default Re: (amy del sol)
great color
Old Jun 14, 2004 | 02:58 PM
EJ1 wilcox's Avatar
Looks great!
I am thinking of painting my wheels soon, I just need to find a spare set to throw on there while I'm painting...
What kind of paint did you use? Clear coat?
How long did it take you?
Old Jun 14, 2004 | 03:09 PM
Charlie Moua's Avatar
Default Re: (koreanwilcox)
Man those pictures are nice but do no justic for how the finish of the rims turned out.
I swear they looked like GM ITR rims when rolling.. hehe
I know who's going to be painting my rims.. LOL
Bump for the nice shots of Joe's EK.
Old Jun 14, 2004 | 03:21 PM
cre18's Avatar
Default Re: (Charlie Moua)
reminds me of roaringturtle's gm 95 gsr's back in the day.
nice job
Old Jun 14, 2004 | 03:23 PM
Richard.'s Avatar
Default Re: (cre18)
not bad.
Old Jun 14, 2004 | 04:11 PM
eJone powereD's Avatar
color is lookin good...great job
Old Jun 14, 2004 | 04:28 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: graphite .. turned out great!.. (JDmEGmaniac)
Old Jun 14, 2004 | 04:31 PM
dawalude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by koreanwilcox &raquo;</TD></TR><TR><TD CLASS="quote">What kind of paint did you use? Clear coat?</TD></TR></TABLE>
based on his choice of color i'll say he went with the duplicolor graphite wheel paint. clearcoat isn't neccessary but its more of an option for a more glossy shine as well as a protectant against rock chips.
Old Jun 14, 2004 | 04:55 PM
BoostedSi's Avatar
Default Re: (dawalude)
they came out pretty good, however, not a fan of hammerheads painted
Old Jun 14, 2004 | 04:57 PM
K.F14's Avatar
Looks really good
Old Jun 14, 2004 | 05:00 PM
CW96's Avatar
Default Re: graphite .. turned out great!.. (Phil DeVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil DeVtec &raquo;</TD></TR><TR><TD CLASS="quote">turned out pretty good! good choice on the color.</TD></TR></TABLE>
Old Jun 14, 2004 | 05:19 PM
ill45's Avatar
Default Re: graphite .. turned out great!.. (XxSOHCDriVerxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxSOHCDriVerxX &raquo;</TD></TR><TR><TD CLASS="quote">Looks like it turned out nice
Good Job on the paint </TD></TR></TABLE>
index cards
Old Jun 14, 2004 | 05:30 PM
Ya@inlinePRO's Avatar
definately post a pic when you put the wheels on!
Old Jun 17, 2004 | 09:46 AM
Jules Winnfield's Avatar
Default Re: (kwik2nec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kwik2nec &raquo;</TD></TR><TR><TD CLASS="quote">definately post a pic when you put the wheels on!</TD></TR></TABLE>tru
Old Jun 17, 2004 | 10:00 AM
silverEH2's Avatar
gotta put the wheels on your car first
Old Jun 22, 2004 | 11:12 AM
Default Re: graphite .. turned out great!.. (silverEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 &raquo;</TD></TR><TR><TD CLASS="quote">gotta put the wheels on your car first </TD></TR></TABLE>
here you go..
https://honda-tech.com/zerothread?id=903298
Old Jun 22, 2004 | 11:41 AM
I3ackfire's Avatar
Ya, I defiantly like the color
V-TAK EG
May 18, 2011 10:50 AM
Phunky Phong
Appearance Build Threads
Oct 1, 2010 07:51 PM
lude98SH
Dec 29, 2005 10:20 PM
FK00GSR
Apr 7, 2004 05:21 PM
1SpoolnH
Nov 25, 2002 08:00 PM
