oem alignment for stock R
Old Jun 14, 2004 | 12:38 PM
magic hat #9's Avatar
Default oem alignment for stock R
yes, yes old news. i would look it up in my helms but i seem to have misplaced it
what is the stock alignment for the R? from looking around with the search function, i gather it's: 1/16" total toe out front and 1/16" toe in rear. sound good?
ps: i tried 3/16" toe out up front and wore off the inside edges of my azenis in no time
pps: the R has stock suspension
Old Jun 14, 2004 | 01:00 PM
Chris F's Avatar
Default Re: oem alignment for stock R (magic hat #9)
Sorry, my Helm's at home.
That sounds fine to me, I run 0 rear, 1/8th total toe out front. YMMV. More toe out in front you can stand, the better Just rotate more often. The only bad thing about front toe out is straight line stability and tire wear.
-Chris
Old Jun 14, 2004 | 06:22 PM
anybody have the acura recommended toe alignment settings? please?!
Old Jun 14, 2004 | 07:25 PM
ZygSpeed's Avatar
Here goes:
Camber
front -0 degrees 30 seconds
rear -0 degrees 45 seconds
caster
front 1 degree 10 seconds
total toe
front 0 mm / 0 in.
rear in 2mm / in 1/16 in.
Old Jun 14, 2004 | 07:48 PM
Default Re: oem alignment for stock R (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Here goes:
total toe
front 0 mm / 0 in.
rear in 2mm / in 1/16 in. </TD></TR></TABLE>
thanks, ed!
wow, i would've thought 1/16" toe out front and 0" toe rear. anyway, i'll use those numbers tomorrow.
Old Jun 14, 2004 | 07:58 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">wow, i would've thought 1/16" toe out front and 0" toe rear. anyway, i'll use those numbers tomorrow.</TD></TR></TABLE>
The 1/16 front toe out and 0 rear are the prefered "track" settings (as George mentioned), the ones I gave are out of the book stock settings.
I'd go with the track settings (and will myself once the new Buddy Clubs come in and get installed).
Better turn in and less rear instability under braking with the track settings. Ed
Old Jun 15, 2004 | 01:04 AM
George Knighton's Avatar
H-T Order of Merit
... less ...instability under braking with the track settings. </TD></TR></TABLE>
Ed, I'm not sure why you said that. Do you mind explaining?
Old Jun 15, 2004 | 03:31 AM
MattD@Stoptech's Avatar
Default Re: oem alignment for stock R (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">
Ed was probably thinking toe OUT in the back...
Toe IN in the back = more stable than Zero toe in back = more stable than toe out in back.
BTW, mugen trailing arm bushings do wonders if j00r car has a tendency to wander under braking in the back. G00t luck finding them though
Old Jun 15, 2004 | 03:52 AM
Dan GSR's Avatar
Default Re: oem alignment for stock R (El Pollo Diablo)
and then have fun installing them
unless j00 got 20 ton press
Old Jun 15, 2004 | 04:14 AM
Default Re: oem alignment for stock R (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">and then have fun installing them
unless j00 got 20 ton press </TD></TR></TABLE>
I bought a used one...just have to pick it up
Thanks for the help Dan!
Old Jun 15, 2004 | 05:08 AM
H-T Order of Merit
I would like to meet Joo one of these days. Everybody talks about him but I've never seen him around.
You'd think I'd have seen Joo at a track meet by now.
Old Jun 15, 2004 | 05:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">I would like to meet Joo one of these days. Everybody talks about him but I've never seen him around.
You'd think I'd have seen Joo at a track meet by now.</TD></TR></TABLE>
Key to meeting j00 is spelling his name right
Old Jun 15, 2004 | 05:30 AM
.RJ's Avatar
.RJ
j00z needs a press for trailing arm bushes? I thought the came out wif a hamma?
Blacksole
Honda S2000
Nov 9, 2011 06:58 AM
98civdx
Suspension & Brakes
77
Jan 26, 2011 10:14 AM
AzntaggeR
18
May 1, 2004 03:21 AM
mstewar
Apr 5, 2003 04:45 AM
Reid
Jul 5, 2002 01:24 PM
