Just installed cams, engine temp. gauge not working
Old Jun 14, 2004 | 07:55 AM
dvp95's Avatar
Default Just installed cams, engine temp. gauge not working
Hey guys, I just installed a set of crower 2s and springs and retainers on my h22. The car runs like normal, but now the engine temperature gauge in the cluster always reads cold. I have a feeling that it is one of the plugs for a sensor that I messed up thats doing this. If you look at the head from the passenger side, it is the right most sensor just to the left of the upper radiator hose. The plug was really weird because it did wasnt a normal plug where you just snap and pull apart; the plug was connected to the wire and when it cracked open, it exposed a spring inside the sensor and a flared end for the wire side. I wasnt sure how it connected so i just put the flared end in the sensor where the spring was and started the car. Any ideas? I know the fan still works because it turned on when I was idling the car for awhile. Thanks.
Oh, one more thing. The car would not start the very first time. It sounded like it wanted to, but it didnt get any spark. So when I opened up the distributer cap, the end of the rotor was all brown. I sanded it down and then the car fired up. This is the second time and seems like the rotor cant handle the spark from my msd digital 6+, ss coil, and wires. Any ideas on this? Anyone make a better rotor? Thanks again.
Old Jun 14, 2004 | 07:28 PM
dvp95's Avatar
Default Re: Just installed cams, engine temp. gauge not working (dvp95)
anyone?
Old Jun 14, 2004 | 07:40 PM
Sunrise City Rider's Avatar
That ECT, Engine Coolant Temperature, sender is busted...Get a new one and you'll be fine...
Old Jun 14, 2004 | 07:41 PM
Use an OEM Rotor
Old Jun 14, 2004 | 08:03 PM
dvp95's Avatar
Default Re: Just installed cams, engine temp. gauge not working (Sunrise City Rider)
Is that the sensor that Im talking about that is to the left of the upper radiator hose? Thanks for the help guys.
EF_SEDAN_LOVER
Nov 20, 2014 04:06 PM
CRX-CHACE
Jun 30, 2013 02:45 PM
DRatedA.W.D.
18
Dec 14, 2011 10:10 AM
BlackShingo
May 20, 2010 07:36 AM
Ryanman
Feb 10, 2008 11:51 AM
