HCP mounts which bracket for rear mount?
Hi guys,
I am going to be buying the HCP mount kit from jdmshit in a little bit, and I wanted to check and see which rear mount bracket I need for the HCP kit.
I already have a 90-93 Teg drivers side bracket, now I just need to know if I also need a 90-93 rear bracket,or if the one I need is from a 94+ GSR or LS. I am pretty sure I need the 90-93 rear bracket, but I just want to make sure with you guys.
Also for the tranny mount, should I use OEM studs and nuts or should I get some grade 8 or 9 bolts and use those for the tranny mount? I am using a 93 LS tranny with my B18C swap, and the tranny does not have any of the studs right now.
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1st-hybrid »</TD></TR><TR><TD CLASS="quote">I have the HCP kit and I used the 90-93 rear mount in my crx, and in my hatch.
I also used the OEM bolts
COol, I just wanted to make sure. I'm gonna be getting the 90-93 rear bracket then from another H-T member.
But one other thing I wanted to ask was if it matters which bolts I use to secure the rear mount to the block? It looks like there are 3 bolts (two of which are the same size) that I need to get to secure the rear mount to the block. But I dont know if I need the 90-93 LS bolts or if I have to use the 94+ GSR bolts and washers.
Can anybody help me out with this?
TIA
</TD></TR></TABLE>COol, I just wanted to make sure. I'm gonna be getting the 90-93 rear bracket then from another H-T member.
TIA
Also, I dont know if it matters but I have a 90-93 YS1 LS tranny for the B18C if that makes a difference.
TIA
TIA
88_T-Rex
Aug 2, 2005 07:25 AM
