2001 type r ecu fit on 2000 gsr thanks
Old Jun 14, 2004 | 04:49 AM
acuraqc's Avatar
Default 2001 type r ecu fit on 2000 gsr thanks
hi 2001 tyepe r ecu fit on 2000 gsr whith skunk2 manifold and 8600 cutt with skunk2 stage 2 its ok ? thanks
Old Jun 14, 2004 | 05:48 AM
steven975's Avatar
Default Re: 2001 type r ecu fit on 2000 gsr thanks (acuraqc)
i would at least get some ITR intake springs and move the GSR's intake springs to the exhaust side.
I don't think the GSR valvetrain is going to do 8600 reliably day in, day out.
Old Jun 14, 2004 | 06:10 AM
btleier's Avatar
Default Re: 2001 type r ecu fit on 2000 gsr thanks (steven975)
I really don't think that 400 rpms is going to make that much of a difference, where you have to run to replace the valvetrain.
Old Jun 14, 2004 | 06:13 AM
PM-Performance's Avatar
Default Re: 2001 type r ecu fit on 2000 gsr thanks (btleier)
the type R ecu wont work unless you de activate the immobilizer.
Old Jun 14, 2004 | 07:39 AM
SuzukaBlueAP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuraqc &raquo;</TD></TR><TR><TD CLASS="quote">hi 2001 tyepe r ecu fit on 2000 gsr whith skunk2 manifold and 8600 cutt with skunk2 stage 2 its ok ? thanks</TD></TR></TABLE>
The ECU will physically fit in the location of the GSR ECU, yes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steven975 &raquo;</TD></TR><TR><TD CLASS="quote">i would at least get some ITR intake springs and move the GSR's intake springs to the exhaust side.
I don't think the GSR valvetrain is going to do 8600 reliably day in, day out.</TD></TR></TABLE>
What for? You show no evidence to support this. While it may be a good idea, there is more to higher revs than valve springs. What is the difference in lift from the GSR springs to the junk2...I mean, Skunk2 cams?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">the type R ecu wont work unless you de activate the immobilizer. </TD></TR></TABLE>
You are correct.
Old Jun 14, 2004 | 07:56 AM
TurboLSVtecTeg's Avatar
Default Re: 2001 type r ecu fit on 2000 gsr thanks (ScreaminTeg)
I would upgrade the valvetrain just because of the simple fact that he is running the S2 Stage 2's personally. Plus the added stress of the extra rev's. But he can do whatever he wants. But my personal opinion would be to upgrade the valvetrain. He may not see immediate signs. But the long term effect could cause problems.
Also the 00-01 Integra wiring harnesses are the same. So the ecu is plug and play. But you will need to deactivate the immobilizer as stated above.
Sal
Old Jun 14, 2004 | 08:50 AM
acuraqc's Avatar
ok! have full valvtrain skunk2 spring and retenairs skunk2 stage2
Old Jun 14, 2004 | 08:51 AM
2kgs-R's Avatar
Default Re: 2001 type r ecu fit on 2000 gsr thanks (TurboLSVtecTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboLSVtecTeg &raquo;</TD></TR><TR><TD CLASS="quote">I would upgrade the valvetrain just because of the simple fact that he is running the S2 Stage 2's personally. Plus the added stress of the extra rev's. But he can do whatever he wants. But my personal opinion would be to upgrade the valvetrain. He may not see immediate signs. But the long term effect could cause problems.
Sal</TD></TR></TABLE>
That or bring your car to the dealership with new ecu and have your key programmed to match the ecu's immobilizer code.
Old Jun 14, 2004 | 08:52 AM
acuraqc's Avatar
ok thanks but what is the immobilizer???
Old Jun 14, 2004 | 11:32 AM
Its a safety feature on all 00-01 integras. Basically there is a chip in the key. If you dont have the right chip in your key for the car. It wont start. Sort of like a kill switch on an alarm system. Just an added safety feature they put on the OBD-2B cars.
Old Jun 14, 2004 | 11:33 AM
b18c1995's Avatar
the device that recognizes the microchips in the keys. You wont be able to start your car with your key if you have a different ecu.
Old Jun 14, 2004 | 11:42 AM
Default Re: (b18c1995)
NO , its the other way around , you wont be able to start the car with a diff Key if you have that ECU
Old Jun 14, 2004 | 01:03 PM
Padawan's Avatar
Darth ModerVader
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">NO , its the other way around , you wont be able to start the car with a diff Key if you have that ECU </TD></TR></TABLE>
Neither his current ignition key, nor another ignition key will start the car with the ITR ECU installed and no provisions made for the immobilizer. Regardless, I would spend the money on a tunable setup rather than simply buying an ITR ECU, especially with the current modifications to the motor.
Old Jun 14, 2004 | 07:36 PM
acuraqc's Avatar
ok ok thanks alot
Old Jun 14, 2004 | 08:31 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by btleier &raquo;</TD></TR><TR><TD CLASS="quote">I really don't think that 400 rpms is going to make that much of a difference, where you have to run to replace the valvetrain.</TD></TR></TABLE>
it actually does.
Old Jul 13, 2004 | 10:11 PM
2fknlo's Avatar
Default Re: 2001 type r ecu fit on 2000 gsr thanks (dLo GS-RaArRrRrRRRR)
What if the ECU is JDM? and the integra is from the first OBD2 in 96s. Cool
Old Jul 14, 2004 | 07:19 AM
steven975's Avatar
Default Re: 2001 type r ecu fit on 2000 gsr thanks (2fknlo)
yep, 400rpms is a lot. No, I don't have any evidence to support the need for new springs, but NEITHER DO YOU. why not go on the safe side? The ITR has those valve springs FOR A REASON. Engineers who are a hell of a lot more knowledgeable than any of us decided they were needed.
There's lots of people here with the mentality of "hey it runs fine so why don't you go ahead and do it" This applies to anything from turbos to NA setups. Long term effects like crank journals and bearings take time to become apparent. Sure, something may "work" but that doesn't mean it'll achieve a long term reliability target. How many have run 60K miles with a JRSC? I know of a lot whose engines lose compression or just blow up.
On moving the redline up 4000rpm...the crank isn't as balanced, the rods are not matched, and the valve springs are not up to snuff. It may work at 8600 for a while but eventually it will likely break.
RidingMark
Aug 17, 2006 03:22 PM
metal-x
Apr 22, 2003 10:07 AM
WorkForHonda
Apr 11, 2003 04:17 PM
smkngsr
Sep 8, 2002 12:00 PM
