Gas gauge and Tach not working
95 accord coupe EX gas gauge works for the first 1/4 tank then hangs and does not go lower.
A mechanic said he needed to drop the gas tank to work on it...is this true? Can I pick up a new float valve and install ti without lowering the tank?
Tach also does not work. Sproadically it will work and then get stuck.
Is it a wiring connection behind the dash? or something else?
