Strange noise when braking hard
Old Jun 14, 2004 | 12:10 AM
1998_4dr_gsr's Avatar
Default Strange noise when braking hard
Hey guys, before I take my car to MIDAS for a brake inspection. I want to ask you for some opinions. My car makes this WOOOOOK WOOOOOKKKKK WOOOOOKKKK noise when i brake real hard. It goes away when I ease the brake, but when i brake harder it makes that noise again. I checked my pads and there is still some left but not much. Can it be my brake pads going and the sensor is touching the disc, therefore causing this type of noise? Once again the noise is real minimal but still noticable when i brake HARD. Thanks
Old Jun 14, 2004 | 02:35 AM
Slow_Em1's Avatar
Default Re: Strange noise when braking hard (1998_4dr_gsr)
does it thump when you turn?..if so its the wheel bearing..those things go bad fast in integra's/civics
Old Jun 14, 2004 | 07:58 AM
Your Epitaph.'s Avatar
///M Power
Default Re: Strange noise when braking hard (Slow_Em1)
Try new pads first, if the problem isn't solved then persue other options.
Old Jun 14, 2004 | 09:20 AM
..::91TEG-G2::..'s Avatar
Default Re: Strange noise when braking hard (J_D_M_9_4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J_D_M_9_4 &raquo;</TD></TR><TR><TD CLASS="quote">Try new pads first, if the problem isn't solved then persue other options.</TD></TR></TABLE>
there could be numerous of things that could be wrong..
take off ur pads and inspect them.. see if there isnt any rock's imbeded in the pads, or if theres any hard composit metals or whatever in the pad, make sure theres no metal from the pad digging in the rotor, inspeact those too and see if theres any gouges in it, and then look back to the pad.. if its that, u at least got the whole break system out of the way.. then go on to something else
pcguy760
Apr 8, 2007 03:52 PM
ramoneguru
Jun 16, 2005 02:30 PM
lv6l
Jan 6, 2005 02:30 PM
CerealKiller1117
Sep 18, 2003 10:05 PM
BrynnTheSlut
Aug 3, 2003 08:32 PM
