A6 block w/ Y8 head...what timing belt?????
Old Jun 13, 2004 | 05:43 PM
lohatch's Avatar
Default A6 block w/ Y8 head...what timing belt?????
hey guys
i might be doing a mini-me using a D16A6 block and a D16Y8 head. if anyone has done this can you let me know what timing belt you are running with this combo. i have read that sometimes when using a D15b7 and a Z6 or Y8 head you need to use a different belt. any help would be appreciated. thanks
Old Jun 13, 2004 | 05:52 PM
EG8R's Avatar
Default Re: A6 block w/ Y8 head...what timing belt????? (lohatch)
I would say one for the Y8.
Old Jun 13, 2004 | 06:31 PM
dr_latino999's Avatar
Default Re: A6 block w/ Y8 head...what timing belt????? (skelly ed666)
Timing belt + Water Pump = Head
Old Jun 13, 2004 | 07:19 PM
mr. carpenter's Avatar
Default Re: A6 block w/ Y8 head...what timing belt????? (dr_latino999)
y8 . you always use the belt for the head.
Old Jun 15, 2004 | 07:44 AM
Akiraboy's Avatar
Default Re: A6 block w/ Y8 head...what timing belt????? (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">y8 . you always use the belt for the head.</TD></TR></TABLE>
yep 2x
go with the Honda Y8 belt on this one, I used some <U>no name </U>crap from Pep Boys & spent 13hrs tryin to get it in place NO DICE, finally I went to the dealer the next day, bought an OE belt & in like 10 minutes AOK.
Some aftermarket belts suck, they had the same tooth count & everything, but it was like 3/8" to 1/2" too short
dohc4life
Aug 14, 2010 08:50 AM
blinger
Jul 22, 2007 04:33 PM
Y_my_91
11
Dec 6, 2006 07:40 PM
SOHC_MShue
15
Jun 3, 2005 06:18 PM
DA91TEGGY
Apr 19, 2005 03:55 PM
