Good throttle bodies
Any of you guys have any preferences for a good performance throttle body? Basically all i really care about is performance, so i guess the best would be the one which is the most free-flowing, right?? Ive got a crx si, so it would obviously have to fit that.. thanks guys
what are you upgrades?
i mean if you have a stock head and intake manifold it wouldn't make much sense to get a better flowing throttle body because it would be restricted by the rest...now if everything else is ported or aftermarket then you need your large throttle body.
well, actually, i have no upgrades yet- only the tb isnt very smooth- ive cleaned it out, but i figured that my accelerator pedal would be much smoother of i just went ahead and got a nice clean, new, tb. but i am planning on puting on h/i/e plus some nitrous, and eventually a turbo
sometimes stock is better, like in this case, the h22 tb is 60mm or 62mm if you get it from a 5th gen dohc vtec. the intake mani is gonna flow alot better then the current stock one, and both can be had for alot cheaper then an aftermarket 62mm throttle body itself
Getting a bigger throttle body does that requir getting a bigger intake pipe to fit around the throt
DroppedTegra
Jan 16, 2002 06:58 AM
