B16a crx wiring problem, hasport/hondata
For a while my pr3 ecu has been throwing code 23 (knock sensor) and 14 (EACV). when i first wired up my car for vtec i followed the web site of hasport using their wiring harness diagram. it says place a single orange knock sensor in b10, and a white wire in b12. well i just found on the hondata website
that my knock sensor should be in freakin b19. B19 currently has a green/red wire in it. If any of you can help that would be great. Let me know which spot it should be in and what to do with that green/ red wire. i have an extra chiped ecu that overlooks the knock sensor but i really want to get this right. here are the links so you can check it out.
hondata http://hondata.com/techwiringpw0.html
hasport http://www.hasport.com/Tech/Wring/EFDX-VTEC.PDF
89 b16a crx
used to be a dx
pr3 ecu
that my knock sensor should be in freakin b19. B19 currently has a green/red wire in it. If any of you can help that would be great. Let me know which spot it should be in and what to do with that green/ red wire. i have an extra chiped ecu that overlooks the knock sensor but i really want to get this right. here are the links so you can check it out. hondata http://hondata.com/techwiringpw0.html
89 b16a crx
used to be a dx
pr3 ecu
Those instructions only work if you have a Hasport harness. They're not meant to work as a "how to" when converting a harness. If you look at step 3 in the instructions you'll see that you move a wire from B2 to B19. That's an orange wire that is already existing in the harness. It's different than the orange wire that gets plugged into B10.
I do have the hasport wiring conversion. Thats just the problem, ive done everything they said and i have even replaced my sensors with new ones and reset the ecu and i still have the codes. i also have wires in spaces B2 and B4 wich everything else says i shouldnt have.
Well i went out and checked after your first reply and there is still an orange wire in B2. so im guessing that wire was never moved. Im going to give it a shot today and ill post results. What should i do with the wire thats already in b19? just cap it off? Thanks for your help.
Modified by Hybridcrx469 at 5:44 PM 6/14/2004
ac, b16a, conversions, crx, diagram, dx, ecu, efdxvtecpdf, harness, hasport, instructions, pr3, vtec, wire, wiring
