Spedometer is going crazy!
Old Jun 13, 2004 | 10:25 AM
crxforum's Avatar
Default Spedometer is going crazy!
For some unknown reason since I reset my ECU yesterday between 0 and 75KMPH the speedo bounced around like crazy. It jumps like a 15KMPH gap sometimes. It happens worse when I slow down fast or speed up fast like to pass someone. In parking lots when I am going like 10 it says I am going like 20 but then when I hit the brakes to stop it does.
The KMPH unless when I am going really slowly seems acurate. So that is not too bad but the jumping around is annoying and distracting. Anyone know what is going on or how I can rectify this problem?
CRX Forum
Old Jun 13, 2004 | 11:17 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Spedometer is going crazy! (crxforum)
Assuming you have a cable driven speedo,
What the problem could be is that the cable has no lubrication
causing the cable to bind and catch which will cause a fluctuating
speedometer needle.
On mine,I pulled the inside cable out of the cable housing at the transmisson and
greased it with wheel bearing grease..
Old Jun 13, 2004 | 11:24 AM
DXDOHCVTEC's Avatar
^yea it prolly has nothing to do with the ecu mine never worked cause the metal fitting on the end was broke so i pulled it off and re-clamped it on then it started jumping cause i clamped it too tight (keeping the cable from turning freely) then I loosened it and it works fine. So make sure the cable isnt binding on anything
KhmerdudeSiR
13
Nov 12, 2008 01:52 PM
Ronin150
Jun 5, 2004 04:44 AM
DOHCRX
Mar 28, 2003 08:22 PM
