d series motor into a 89 crx but new motor had a hydrolic tranny will that be a problem?
Old Jun 12, 2004 | 09:36 PM
miskone's Avatar
Default d series motor into a 89 crx but new motor had a hydrolic tranny will that be a problem?
I bought a d series motor out of my friend's 94 hatchback dx, which had a hydrolic tranny, but i didn't get the tranny with the motor. I was putting the motor into my 89 CRX Si and I have a cable tranny. I was wondering if it would just bolt right up. If anyone knows anything about this and would care to comment it would help me alot thanks.
Old Jun 12, 2004 | 09:38 PM
HF2ZC's Avatar
Default Re: d series motor into a 89 crx but new motor had a hydrolic tranny will that be a problem? (miskon
Yes, it should just bolt right up. Use the distribotor and ECU from the old engine if you don't want to switch to OBD1.
Old Jun 12, 2004 | 09:53 PM
C uR eX's Avatar
it basically the same setup..but you might want to check up on that intake manifold, casue the 92-up have the MAP sensor on the TB..while the 89 crx has it mounted on the firewall....so you would have to do some minor switching and wiring.
KING PIN
Mar 19, 2007 08:46 PM
EkCivicRunner
May 24, 2006 04:17 PM
4-ageTOg63
Apr 2, 2004 05:36 AM
dasnotjdm
Apr 14, 2002 04:34 PM
