code 9 obd0 MPFI swap on dx
i did mpfi swap on a d15 with a milled A6 head, using a chipped pr4 ecu with pm6 maps and timing curve.
runs great but has code 9 when i hit higher RPM. if i turn the car off and start it right back up after hitting high rpm, the code will be gone.
any help is appreciated.
Modified by zcnos at 9:01 PM 6/13/2004
CPS is code 9. i read the manual and it said to check b10/b12 resistance, should have 350 to 550 ohms. check there and on dizzy, if they are both low it means bad dizzy. if its on the dizzy but not on ecu, its wiring.
Modified by zcnos at 9:20 PM 6/13/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zcnos »</TD></TR><TR><TD CLASS="quote">crank angle sensor is in the dizzy on a d16a6, correct? also, could this code be given if the timing belt jumps a tooth?</TD></TR></TABLE>
i had originally a code 9 w/obd0, i reset the ecu and it disappeared after that. i took it to the mechanic later on who said my timing was a little advanced.
i don't know what that proves, but it may help to check your timing.
i bought the dizzy from here for $25 shipped. i wonder why it was so cheap.......
his email is kylethesaturn@hotmail.com. i forgot what his HT name is.
on a brand new one or remanned? i know the autozone here only sells remanned. that's not to say the remans don't work, i'm using one now. i just wish i had known about dist. king prior and i would've got a brand new one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkZachiel »</TD></TR><TR><TD CLASS="quote">i had a code 9 (crank angle sensor) on my dohc zc a year or so ago. I had to replace my whole dizzy. </TD></TR></TABLE>
how??
code 9 is the cylinder sensor (CYL)
and that sensor is on the exhaust cam of the DOHC ZC , not in the dizzy...
u have a code 4 (crank) u had that problem
please refrain of posting stuff that confuses other people that are reading this threads for knowledge
how??
88efsedanlx
Dec 10, 2011 05:40 PM
ahc'monracing
Oct 8, 2002 04:43 AM
