93 Not geting fuel to engine. causes?
Old Jun 12, 2004 | 03:40 PM
zeke mccune's Avatar
Default 93 Not geting fuel to engine. causes?
Hi
My check engine light has been coming on and I found that it was code 43, fuel supply is faulty. Today the car wil not start unless I spray carb cleaner into the PVC hose. As long as I do this the car will run.
It may be a clogged fuel filter or a bad fuel pump or... Where is the filter on this 4 cylinder car? Where is the fuel pump located? Is there a handy place where I can check to see if the the fuel pump is delivedring fuel?
I am still looking for a FSM but thus far, no luck!
Any help?
TIA,
Zeke
Old Jun 12, 2004 | 05:42 PM
hondadude's Avatar
Default Re: 93 Not geting fuel to engine. causes? (zeke mccune)
The first thing I'd suggest is to check the main relay...search this sight you'll find lots of info
sasinorm01
Mar 19, 2015 09:28 AM
JacksonMade
Jun 1, 2010 07:05 PM
hermtm2
23
Apr 8, 2009 06:17 PM
94typeR
Jun 2, 2007 11:50 AM
crnimacak
Apr 21, 2006 10:11 PM
