88 civic-tranny oil?
I'm not 100% sure for an EF.
It may be the same.
<FONT COLOR="red">----------------------------------</FONT>
On my Eh3 Theres two bolts.
1) take the top bolt off and let the excess fluid drain out
2) take the bottom bolt out and let the rest of the fluid drain out.
3) after all the fluid has drained out put the bottom bolt back in.
4) Your going to need a funnel/tube to stick in the top tube (the bolt has to be off/common sense)
5) fill your tranny fluid up and then have someone below you to put the bolt in as soon as you pull the funnel out.
goodluck bro
*Also
Heres the link to the EF forum:
https://honda-tech.com/zeroforum?id=3
It may be the same.
goodluck bro
*Also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oakfall »</TD></TR><TR><TD CLASS="quote">I guess I really am as dumb as I look.</TD></TR></TABLE>
Yeah, posting an 88 Civic question in the 92+ forum
hate to say this but pre 92 does not mean 92 plus means before 92 nice one on my zc tranny and the si trannys i have run the plug to fill is on the passenger side kinda towards the top of the tranny it is a big *** bolt head cant miss it good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbrodac0424 »</TD></TR><TR><TD CLASS="quote">hate to say this but pre 92 does not mean 92 plus means before 92 </TD></TR></TABLE>
if bauly's on it he probably posted in the eg forum originally and it got moved here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter »</TD></TR><TR><TD CLASS="quote">
if bauly's on it he probably posted in the eg forum originally and it got moved here.</TD></TR></TABLE>
Correcto.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oakfall »</TD></TR><TR><TD CLASS="quote">Thanks for the help Bauley.
So nice of you to respond.</TD></TR></TABLE>
Yeah, next time I won't be so nice.
Correcto.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">1337 h4x0rz 0wnz j00</TD></TR></TABLE>
LOL!!
Have mercy on me!
LOL!!
Have mercy on me!
Hmm If you read this article, Im not sure if the transmission fills the same way.
https://honda-tech.com/zerothread?id=382564
There's the common bolt sitting under on the side of the transmission that holds the fluid in. Basically u know the tranny is full when the fluid starts dribbling out. But however, there is also a speedsensor sitting on the top of the transmission. You unbolt it and it uncovers a hold on the top of the transmission where you can place a funnel and fill the fluid up until it starts dribbing from the bolt under it. Hope that helps man.
Slammd Sol
Mar 28, 2004 10:21 AM
