radiator boils over
hello everyone!! just joined today. i have a 94 accord lx that has started to lose some coolant by boiling over out of the radiator cap. my temp gauge is not reading hot and my fan seems to be working. the coolant level is good thanks to reserve tank that i have to add some coolant to like every 2 days now. any ideas?
thanks
thanks
As the engine warms up from a dead cold condition you should feel a temp difference between the top & bottom radiator hoses. Then after 10 mins or so the T-stat will open up and the hoses will have almost equal temp.
If this does not happen the T-stat needs to be replaced.
You should also be sure the block is burped via the 12mm bleeder at the T-stat housing.
Best of luck I hope this helps you.
89sparks
May 14, 2008 07:38 AM
draperj09
Mar 12, 2007 06:48 PM
PatrickGSR94
Feb 24, 2003 12:27 PM
