QUESTION: fuel cut question
QUESTION : (92-95 civic)
i was wondering if i take my fuel control relay out of my car as fuel cut can theives still activate my car ?
i'm guessing all you have to do is hook up the yel/grn to any positive and that should power the fuel pump...? is this true ?
is this worth doing ? or should i just make a swtich and relay set up ?
suggestions please
thanks in advance...
suggestions please
if youre talkin bout the main relay...sounds like a pain to do, they could loop the with a paperclip. but its easier to put a switch in...an hour if you have the tools
I just did this modification. Works like a charm. After crimping female slide connects and cutting the perfect size wire, took about 15 minutes to install (soldering, splicing, taping). Hide the switch somewhere hidden, off you go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">yeah fuel cut off switch only takes about 30 minutes to wire up.</TD></TR></TABLE>
g2tegsown
Audio / Security / Video
13
Aug 21, 2008 10:30 AM
Mikes2000civicsi
Feb 2, 2008 03:59 PM
JDubya
Apr 1, 2003 06:29 PM
