What the heck? no BOOST!! PLEASE HELP!!!
Old Jun 11, 2004 | 10:37 PM
alpha_1's Avatar
Default What the heck? no BOOST!! PLEASE HELP!!!
i spent the last four days putting together my sohc d16z6 home made turbo kit and now its finally done. i'm having some MINOR difficulties. my questions are:
1. why is my oil light on? when i first fired up the car the light was not on but all of a sudden the light is now on. i check to see if there is oil and the dipstick shows that it has oil and that its full. no oil is leaking from the feed or return line. i even check to see if where i teed my feed line and there is no leaks.
2. my car does not idle. why is that? i'm running dsm 450's with a resistor box and a v-afc hack. my settings are -38 all across untill 5000 rpm. then its -35.m also i retard my camgear 3 degrees and bought 2 step colder plugs gaped at 30.
3. can my resistor box be my problem for not idling? i took the four yellow/black wires that hondata showed me to disconnect coming from the injectors to the power connecter and connected them into the four black wires. then i connected the red wire into ONE of the yellow/black wire going into the power connecter.
4. NO BOOST! when i step on the gas my boost is at zero but when i let go of gas it has a vaccume of -23 then jumps to -13 vaccume and stays at -13. i know i adjusted the wastegate to open at least a 5 psi or more and have a manual boost controller.
please help me! i'm getting stressed out becasue i'm addicted to boost and this car has no boost.
JaysonDC2
Mar 24, 2010 03:04 PM
inspector01
Aug 2, 2008 02:26 PM
xDicktonesx
Jan 10, 2007 03:41 PM
darylfiend11
May 30, 2004 01:50 PM
TurboedGSR
Sep 2, 2002 11:50 PM
