16" rota on 96 civic hatch..?
i like 16's on civics it might fit well depending on whether or not your dropped if your dumped it might not fit. tire size depends again mostly on how much of a drop you have on your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietn712 »</TD></TR><TR><TD CLASS="quote">i ahve a 16" rota would that fit good on the hatchback or is it too big..n wat size tire should i get?</TD></TR></TABLE>
english is your friend.
any ways, 16s will fit your car fine. I wouldn't go any farther then 16s since you will have the tires rub against the fender liners and other parts under the fender. also for tire sizes: 205/45/16 is the perfered size even though you can run 20/40/16, that is like running on a rubber band and has horrible ride quality(I'm talking from experience btw)
well the car is drop pretty low..i had on 14" but it was rubbling when i turn it all the way..so u think 15" wold work find then..? or do i need to get low profile tires?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietn712 »</TD></TR><TR><TD CLASS="quote">well the car is drop pretty low..i had on 14" but it was rubbling when i turn it all the way..so u think 15" wold work find then..? or do i need to get low profile tires?
you need to raise the car up if the it's rubbing on 14s. that has no benefits to drop it that low and is a danger to yourself and others around you on the road. I won't lowerd it more then 2 inches. anything more then that is for SHOW purposes only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietn712 »</TD></TR><TR><TD CLASS="quote"> or do i need to get low profile tires?
reread my post earlier^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietn712 »</TD></TR><TR><TD CLASS="quote">even though you can run 20/40/16, that is like running on a rubber band and has horrible ride quality</TD></TR></TABLE>
Uh .. 20/40/16 would be like ACTUALLY running on a rubber band lol.
wat is the setup on that?..those are 16" right???like i said my car is drop pretty low..n i dun want to be ridding on rubber bands..i want a normal ride w/out tire rubbing too much....
