V-AFC owners...
Old Nov 13, 2001 | 05:12 PM
oryanh's Avatar
Default V-AFC owners...
Anyone have one of these fail?
I just purchased one from a local shop and am anxious to install it.
Question... How does the V-AFC determine default fuel maps, once initializations are complete?
thanks.
[Modified by oryanh, 6:35 PM 11/13/2001]
Old Nov 13, 2001 | 05:21 PM
STOLEN - ITR 98-0652's Avatar
Default Re: V-AFC owners... (oryanh)
It doesn't. It's a piggy-back. It changes your fuel by altering MAP sensor voltage to the real ECU.
Old Nov 13, 2001 | 05:24 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: V-AFC owners... (ITR 98-0652)
I have never heard of one failing, if it did break (im not an electrical engineer so i might be wrong) i believe it would still work as the circuit would not be broken.The VAFC just alters signals to the ECU, if it broke the signals would still continue but would be unaltered.
Old Nov 13, 2001 | 05:34 PM
oryanh's Avatar
"It changes your fuel by altering MAP sensor voltage to the real ECU."
Map sensor? -expound on that please.
I should kick myself for buying one when I'm not too sure how it works.
Old Nov 13, 2001 | 05:39 PM
BABY NSX's Avatar
Default Re: V-AFC owners... (Rguy)
Wrong...
If the VAFC fails your ECU will not receive a good MAP signal.
If you have one installed and your engine is running fine then the VAFC is working fine! If you haven't noticed anything after installing it, that is because you haven't tuned it yet
And if you don't know how or what it does then you definitely don't want to try messing with it!
Good luck!
Regards,
oryanh's Avatar
One more question... My plan is to install, and leave fuel correction alone; at default. -Can I assume this would mean it is operating same as stock?
...And if air/fuel is adjusted, would an air fuel meter be wise? or should this be monitored done at the Dyno?
Old Nov 14, 2001 | 08:40 AM
oryanh's Avatar
Old Nov 14, 2001 | 09:07 AM
BABY NSX's Avatar
All tuning should be done with a Wide Band 02 sensor and on a dyno!
I have never played with a VAFC but I would bet that if you don't touch a thing after installing it then you should see no changes in the engine performance. I would confirm that the VTEC points are the same as they might be set to a different default. If you change the VTEC points without fuel enrichment or enleanment then you might screw things up around the x-over point.
Regards,
Old Nov 14, 2001 | 09:13 AM
Willard's Avatar
Yes... but with little blue lights to look at... plus the ability to move the X-over point.
Will
Old Nov 14, 2001 | 10:15 AM
oryanh's Avatar
Default Re: V-AFC owners... (Willard)
Nice... So could someone help me out, or provide a resource for the initial setup.
This may sound strange but, I don't trust the manual for setup.
It reads: Page 20 "Never start the engine or turn the ignition key Off/On while the VAFC is in use." -What the hell is that supposed to mean?
If someone could send over thier settings for setup without the air fuel stuff, I would be soooo happy.
chrisdata
Sep 18, 2004 04:37 PM
ArchAngel Sabastian
Jan 3, 2003 08:13 AM
R@mon
Oct 6, 2002 01:08 PM
VTECHGSR
Dec 13, 2001 04:30 PM
