what am i missing? Building B16A..
Old Jun 11, 2004 | 03:53 PM
Downey's Avatar
Default what am i missing? Building B16A..
getting tired of the D16Z6 and shitty gearing, so i got myself a JDM 2nd gen B16a.
before it goes in i thought id build it up a little. heres are the things ive got for it so far.
can you guys help me out, take a look at it and see if i missing anything, or give me some suggestions on better parts.
92 B16A
AEM Cai
Stock tb bored to 4mm over (stock was 62)
AEBS manifold
Hondata manifold gaskit
Stage 2 port & polish by BlackTrax Racing
Mugen headgaskit (10.7:1)
Skunk2 stage 1 cams with AEM cam gears
Portflow inner springs, ITR outers with Portflow titanium retainers
JDM 4-1 header 2.5" collector
5zigen 4-2-1 header with 2.25" collector.. which one would be better for the b16?
Carsound 2.5" highflow cat
RSR 2.36" exhaust
ACT-HD-SS clutch with Fidanza flywheel
CTR N1 crank pulley
On the way..
Hondata S200, RC440 injectors, b&m fpr, and stock itr fuel pump.
am i missing anything? what do you guys think? can anyone recomend a good spark plug to go with?
should be all together within a month, will post dyno results.
Old Jun 11, 2004 | 03:56 PM
DefiantGSR's Avatar
Default Re: what am i missing? Building B16A.. (Downey)
jdm 4.7 final drive..
Old Jun 11, 2004 | 04:01 PM
Downey's Avatar
Default Re: what am i missing? Building B16A.. (DefiantGSR)
ive got a 98 spec jdm r tranny (4.785 fd gsr 4th/5th) on its way. should be here in about 5-6 weeks.
Old Jun 11, 2004 | 04:11 PM
THCk20eg's Avatar
displacement
Old Jun 11, 2004 | 04:15 PM
Downey's Avatar
yea yea.. make fun of the 1.6 if you want.. 1.6 is fine.
this motor is only temporary (6-8 months) then ill be throwing in a JDM K20-R.
Old Jun 11, 2004 | 04:19 PM
B_CRUZ!'s Avatar
honestly I would get a p72 head to bump up compression a little more and sell that mugen head gasket and buy a honda OEM one. Then get a skunk2 manifold or AEBS if it is even available. Check the classifieds for a CTR exhaust mani for less that $200. It has a 2.5" outlet and has excellent ground clearance.
Old Jun 11, 2004 | 04:32 PM
DefiantGSR's Avatar
personally, i dont like the 98 spec itr tranny. the gsr 4th doesn't appeal to me...
Old Jun 11, 2004 | 06:56 PM
Downey's Avatar
Default Re: what am i missing? Building B16A.. (BDCruz)
whats wrong with the jdm 4-1 or 5zigen 4-2-1?
ctr cams over stage 1's?
Old Jun 11, 2004 | 07:35 PM
92RED Hatch's Avatar
Dude your stock tb was not 62 mm.....i may have miss understood reading it...i prob was....since four over would be 62......sorry for the waste of space and post...
Old Jun 11, 2004 | 07:37 PM
Default Re: what am i missing? Building B16A.. (92RED Hatch)
nothing is wrong with 98 spec jdm 4-1 header...i have it and love it better top end...plus after it was tuned gained 8 hp
Old Jun 11, 2004 | 08:15 PM
DefiantGSR's Avatar
im not talking about the header...i'm talking about the jdm itr tranny you're getting. the gsr 4th that it has isn't very appealing to me as its only going to slow you down. but to each their own.
Old Jun 11, 2004 | 08:40 PM
RABHonda's Avatar
ditch the mugen head gasket. mill the head.
Old Jun 11, 2004 | 09:02 PM
dfoxengr's Avatar
Default Re: what am i missing? Building B16A.. (RABHonda)
yeah a mugen gasket is too much money.
Old Jun 11, 2004 | 10:04 PM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RABHonda &raquo;</TD></TR><TR><TD CLASS="quote">ditch the mugen head gasket. mill the head. </TD></TR></TABLE>
I wouldn't do that because it throws off the timing too much IMO.
Old Jun 11, 2004 | 10:48 PM
dfoxengr's Avatar
a mill is the same as a smaller gasket
Old Jun 11, 2004 | 11:32 PM
Downey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92RED Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Dude your stock tb was not 62 mm.....i may have miss understood reading it...i prob was....since four over would be 62......sorry for the waste of space and post...</TD></TR></TABLE>
i measured it with a digital caliper.. and yes it was 62mm stock.
Mugen head gasket has been bought already. i could mill the head if i want to get some more compression.
Old Jun 11, 2004 | 11:36 PM
importboi22's Avatar
dont need to port the head on a b16, just get a good valve job from portflow and some rocket/omnipower valves and mill the head 2 thou while you have it off
Old Jun 11, 2004 | 11:40 PM
Austin's Avatar
Default Re: what am i missing? Building B16A.. (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">a mill is the same as a smaller gasket </TD></TR></TABLE>
A headgasket is reversable, a mill is not. I'd not mill the head since it's a temporary engine, and the value of the head would be more if it was unmilled.
Austin
Old Jun 13, 2004 | 06:11 AM
RABHonda's Avatar
Default Re: what am i missing? Building B16A.. (importboi22)
you think portflow is the only ****** place in the united states that can do a damn valve job? give me a ****** break.
take that head to a machine shop, tell them you want reversion in the exhaust ports, back cut all valves, and a 5 angle valve job.
Old Jun 13, 2004 | 10:39 AM
dfoxengr's Avatar
Default Re: what am i missing? Building B16A.. (Austin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">
Austin</TD></TR></TABLE>
i was talking in compression only terms.
that is assuming you dont cut into the quench too much
Old Jun 13, 2004 | 10:46 AM
B_CRUZ!'s Avatar
IMO I would rather deal with a smaller combustion chamber like the p72 head and just get that head worked on and use a regular 3 layer gasket. One of the first motors I built was a b16 block/p72 head set up with CTR cams and it was a hell of a ripper with 92 octane(yeah it was that long ago). Too bad it got stolen before we had a chance to dyno it but it would give 1.8 GS-R hatchbacks a run for their money.
Chris_EK9
Aug 31, 2008 05:41 PM
VTEC2841
59
Jul 9, 2007 07:02 PM
efit
70
Apr 5, 2005 05:32 AM
AllMotor92EG
Jul 1, 2004 12:24 PM
virginia_dude
Jan 30, 2004 05:05 AM
