motor swap PROBLEM.......pls HELP!!!!!!!!
Just swapped a LS/VTEC into my 93 CX civic, motor was dropped in and everything hooked up right, but then as i TURNED the KEY.....my car was strugglin to start it turns over but just wont start, its chchchchchchch VROOM chchchch VROOM VROOM chchchchchchchchch. I checked for spark and yes there is spark, does anyone know wat might be wrong with it?
Oh and i forgot to mention im using a OBD0 distributor from a CRX and wired the OBD1 distributor plug onto the OBD0 one. all colors match up except 1 on the OBD1 plug which is i think yellow/blue? HELP? pls.
Sorry I wouldnt know the wiring off hand, but the first thing I would check is to make sure the wires are in the correct firing order on the distributor.
ionno.............but i checked all ther COLOR on the wires. all MATCHED up except yellow/blue on OBD1 plug and there was ALSO 2 cream colors on the OBD0 distributor? i mix and match those wires and still the SAME results. My brother which knows pretty much about hondas cannot figure it out either. We know its the DISTRIBUTOR but we cant figure out wat color wires go to which.
And also ill answer alot of other peoples questions by saying this..... i am not gonna buy me a new distributor!!! 300 bucks is money i dont have on a distributor, all though yes i do want to buy a new one just cant afford it now, and no junk yards have it for cheap either. the junk is running $200 for a LS distributor so pls help a BROKE BROTHA OUT.
do you have any friends that have a b series motor? and check if spark plug is new i too ran into the same prob bought new spark plug and worked fine
so after it cranks it wont stay running? it just kicks over but wont idle? check the ECT sensor if the ecu is reading hot from the sensor it will make the fuel mixture wrong and it wont run right. i had the same prob with an h22 accord. turns out i had two of the plugs switched and it was supplying constant voltage to the ECT sensor. good luck
you can't use an obd0 distributor on an obd1 car even if you rewire. I tried it before, it didn't work so I just found an obd1 distributor. You can use an obd2 distributor too.
Yea i checked my spark plug wires..they are in the correct order. And for INLENE4 are u ABSOULUTELY sure that i cant use a OBD0 distibutor for a OBD1 car even if i rewire it? Is there anyone who has tried to do this, could anyone pls tell me so i wont have to waste my time trying to figure it out? i SPENT 2 weeks and counting on trying to figure this solution out. If anybody can tell me let me know. Thanks.
These guys say you can't do it
https://honda-tech.com/zerothread?id=594364
This is a thread about obd1 dizzy in an obd0 car, it seemed to have worked for some people, but others said it won't work.
https://honda-tech.com/zerothread?id=651998
Good luck.
I'd suggest just looking for an obd1 dizzy or obd2 and rewiring it.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inline4 »</TD></TR><TR><TD CLASS="quote">These guys say you can't do it
Good luck.
I'd suggest just looking for an obd1 dizzy or obd2 and rewiring it.</TD></TR></TABLE>
yeah but if you look at the creator of the second thread he was converting to obd1. so thats why it works. you cant use an obd0 distributor in an obd1 car. im absolutely positive on that one
Good luck.
THANKS for the info inline4 and boostedj1!!!!!! now i dont have to stress myself that problem. 2weeks of hard thinking and finally got the answer. Thanks alot. NEW DISTRIBUTOR HERE I COME.
94eg5squadMD
20
Nov 24, 2006 08:12 PM
Audipwr1
May 10, 2003 05:17 PM
thats my guess
