energy suspension bushings
Old Jun 11, 2004 | 11:37 AM
Rostr02's Avatar
Default energy suspension bushings
Heres the problem. I bought the energy suspension master set for my 91 crx. I have a teg rear disc setup waiting to go in but I need the bushings to complete the set. I need these bushings asap so I can have the disc setup ready to go in on June 18th, due to my KW varient III coming in and an auto cross that sunday. If need be I will buy the mugen ones but they will not get to me on time and plus they are expensive and not poly. I need the compensetor arm bushings, rear lower arm, and rear lower arm bushings.
Old Jun 11, 2004 | 11:56 AM
6MTV6's Avatar
Default Re: energy suspension bushings (Rostr02)
I have the master set for my 91 DX HB. I'm also doing a rear disc swap.
I can't use the bushings from this set for the Teg trailing arms?
Old Jun 11, 2004 | 12:00 PM
Furyof4's Avatar
Default Re: energy suspension bushings (Bishop4G)
I don't think the master kit comes with the rear trailing arm bushing and thats the only bushing thats different than the civic, so yes you can both use the kit with your rear discs...i do.
Old Jun 11, 2004 | 12:40 PM
EL Vap133's Avatar
So you're looking for parts to buy?
Old Jun 11, 2004 | 01:39 PM
6MTV6's Avatar
Default Re: energy suspension bushings (Furyof4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think the master kit comes with the rear trailing arm bushing and thats the only bushing thats different than the civic, so yes you can both use the kit with your rear discs...i do. </TD></TR></TABLE>
What? What else would these 3" poly donuts for?
They're the same width as the Teg trailing arms. I can push the bushings from the Civic/CRX Master kit in to the Teg arms by hand. But the Pin won't fit through the hole in the bushing. I thought they probably just had to be pressed in hydraulically.
Old Jun 11, 2004 | 06:44 PM
Rostr02's Avatar
I have the mugen rear trailing arm bushing. the bushings i need is the rear upper and lower control arm and the compensetor arm bushing
Old Jun 11, 2004 | 06:47 PM
Rostr02's Avatar
Default Re: energy suspension bushings (EL Vap133)
I am looking to see if i am missing some of the bushings in the set or i am over looking something in the kit. But if need be i will post in the classfieds for the right part. I am not looking to buy unless the master kit does not have what i need.
Old Jun 11, 2004 | 07:33 PM
spaceman's Avatar
go to the es website,get the part #'s for what you need then go down to your local shop that has the bushings you need dood..
Old Jun 14, 2004 | 04:19 AM
Furyof4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bishop4G &raquo;</TD></TR><TR><TD CLASS="quote">
My master kit didn't come with them sorry. You sure they're not the radius rod bushings?
Old Jun 14, 2004 | 04:33 AM
90civichbsi's Avatar
are you not running stock lower arms with the swap? bushings fit fine in them and they will work with the rear disc swap
Old Jun 14, 2004 | 07:24 AM
Wes V's Avatar
Default Re: energy suspension bushings (90civichbsi)
The main bushing on the (rear trailing arm) Integra's is larger in diameter. Plus, the shaft is larger in diameter.
You could call Lighting Motorsport (ask for Tom) and see if they have them in stock. (800) 478-0952 If they are in stock, you could get next day delivery.
You could also use the stock rubber bushings (yes, they are available without the arm) The part number is 52385-SK7-N02 for the Integra ones. You can order them at a Honda dealer and you should also request a copy of Service Bulletin 00-006 (dated December 11,2001) for information on installing them (you have to have a shop with a LARGE press install them) It should be noted that the bushings that would be used on "Honda" arms is different.
Wes
Old Jun 14, 2004 | 08:04 AM
LilGreenMachine's Avatar
Default Re: energy suspension bushings (Wes V)
I want to do this mod.
Old Jun 14, 2004 | 08:08 AM
6MTV6's Avatar
Default Re: energy suspension bushings (LilGreenMachine)
I'm using the stock compensator arm. I'm replacing the upper/lower control arms and the trailing arms from a Teg. I guess I have a set of trailing arm bushings for an 88-91 civic/crx for sale then.
Scrpn17w
Apr 1, 2009 06:28 PM
GSRCRXsi
Jul 5, 2004 12:47 PM
Jdm93civic
Aug 15, 2003 05:35 AM
redciviclx14
Jul 12, 2003 02:29 PM
SPiFF
49
Mar 26, 2003 04:26 AM
