throttle cable tension
i just installed a new mod that goes in between the throttlebody and the intake manifold (in other words, air goes thru the filter>intake>TB>"new mod">intake manifold>engine) and the tension in the throttle cable is increased because it is extended a little less than an inch. Throttle response increased also, but the gas pedal has barely any free-play. Is this ok that the tension is increased like this?
A common thing to do to the cars is to tighten the throttle cable to eliminate excess "play".
prolly a Tornado
Now that you mention it...I remember doing this to YOUR car at the Expo!!
You could try that, but as soon as he sees the stickers all over your car in that pic, there's going to be no doubt in his mind that you are a punk-*** riceboy! You'll get a ticket either way...
Stock "free-play" is 10-12mm in the throttle cable. If you have too much play, you will FEEL like you are missing the throttle response, 'cause you are! In fact, if it is too loose, you can actually not end up at full throttle when your foot is to the floor. Too tight & your idle will kick up a notch...
Adjust it tight & LOOOOOOOVE the feel of "touch&GO!"
BudMan
BudMan
BryanM.
Jan 10, 2022 04:16 PM
fast+forward
Sep 27, 2006 04:44 PM
