anyone know the transmission fluid and gear oil #s???
i have a 96 ex sedan w/ a 5-speed and was looking to flush my transmission this weekend and replace it with royal purple fluid and gear oil. anyone know what viscosities i need to use?? cant find this info anywhere. i think its a 75w90 but im not sure. any help would be greatly appreciated.
save yourself the headache and just use regular Honda MTF. one viscosity fits all. there is no need to use anything fancy unless you're racing your car everyday/weekend.
-edit
something else i just came across. your car is a SOHC sedan...not a racecar. just stay with OEM.
-edit
Hey your name is exactly what your trans will be if you put 75w90 oil into it. If you can't use honda mtf, then you can go with 10w30 oil. 5w40 syntec if you wanna waste some money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondadude »</TD></TR><TR><TD CLASS="quote">Hey your name is exactly what your trans will be if you put 75w90 oil into it. If you can't use honda mtf, then you can go with 10w30 oil. 5w40 syntec if you wanna waste some money. </TD></TR></TABLE>
can you use regular engine oil in the transmission fluid?
I saw a post on here that said the GM fluid was really good. I think a guy tried different types in a B18. Just throwing that in, but I would just stick with the Honda stuff if I were you.
thiscivicuser
17
Mar 3, 2008 08:45 PM
