high beam lights
take a look on this website i found abt high beams lights http://fourthgenhatch.com/index2.html and i was wonder will this work if i get 2 high beam plugs with wires on them and just cut and rewire them on a low beam wires? will it work ? and i want to know so i can do this tmw
hold a high beam bulb next to a low beam bulb, look inside the plug, all you need to do is modify the high beam bulb to fit in the low beam socket, takes about 30 seconds per bulb.
Doing this doesn't cause any problems with wattage? The high beams operate on higher wattage than low beams. When I bought my lights I looked for those that operated at 55W for low and 65W for high, just like stock. This isn't going to melt any wiring or anything???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsidude91 »</TD></TR><TR><TD CLASS="quote">so ur saying if i use it too much i will fry my light blub wire ? and the fuse too ?</TD></TR></TABLE>
The fuse is designed to blow before the wire opens. That's a fuse's purpose....
Audemon
Mar 6, 2016 03:15 PM
