Are there any negative side effects to higher air/fuel ratio from I/H/E?
Old Jun 10, 2004 | 09:16 PM
EricUSC's Avatar
Default Are there any negative side effects to higher air/fuel ratio from I/H/E?
I am planning to get the basic I/H/E bolt-ons from Comptech soon. All of the dyno graphs from their website look very impressive. The air/fuel ratio will increase with these bolt-ons. I am very hesitant to tune the air/fuel ratio or get a fuel pressure riser because I don't want to worsen the fuel economy or increase emissions. Are there any negative side effects of a higher air/fuel ratio besides the fact that you can get more power from a lower ratio?
I have a Civic EX w/ a D16Y8 (Please don't mess up this thread by telling me to screw I/H/E & go turbo or to get a swap.)
Old Jun 11, 2004 | 06:47 AM
EricUSC's Avatar
Default Re: Are there any negative side effects to higher air/fuel ratio from I/H/E? (EricUSC)
Old Jun 11, 2004 | 06:56 AM
Luserkid's Avatar
I dont see why the a/f ratio would raise off of bolt ons. Im sure youll be fine.
Old Jun 11, 2004 | 07:51 PM
EricUSC's Avatar
Default Re: Are there any negative side effects to higher air/fuel ratio from I/H/E? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">I dont see why the a/f ratio would raise off of bolt ons. Im sure youll be fine. </TD></TR></TABLE>
More air, same amount of fuel = higher a/f ratio.
Old Jun 11, 2004 | 08:22 PM
h22John's Avatar
You'll be perfecly fine..................John
Old Jun 11, 2004 | 08:25 PM
JDMlyfestyle's Avatar
it will have a change but nothing to drastic to cause any major problems. if u had a FPR bump up the psi 3-5 psi and u should be fine
Old Jun 11, 2004 | 08:27 PM
EricUSC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EricUSC &raquo;</TD></TR><TR><TD CLASS="quote">Are there any negative side effects of a higher air/fuel ratio besides the fact that you can get more power from a lower ratio?</TD></TR></TABLE>
Anybody have the answer to this question? I know I'll be fine, but I'm going for long term reliability, fuel economy, and low emissions.
Old Jun 11, 2004 | 08:29 PM
Civic_95_Si's Avatar
Default Re:
A good AF ratio for NA is 13.2-13.8. With out any tuning and a few bolt-ons my D16 is running mid 12 AFR. I dont think it's gonna go too lean on you.
Chops13
Engine Management and Tuning
Jun 16, 2013 07:25 PM
chomander
May 4, 2004 01:41 AM
Turbohatch
Dec 15, 2001 12:21 PM
97LudeSH
Sep 5, 2001 01:23 PM
