CX Exhaust question
Old Jun 10, 2004 | 08:46 PM
matthewmathis's Avatar
Default CX Exhaust question
I purchasred an exhaust for my hatchback before seeing which models it would work with. Now, because of my cat being attatched directly to my headers, I have about a 1 ft gap in between where my "cat-back" exhaust starts and my downpipe ends. The question is whether I would be able to buy a resonator/test pipe off of ebay and have it bolt up directly?
Old Jun 10, 2004 | 08:47 PM
dogfood's Avatar
Default Re: CX Exhaust question (matthewmathis)
why not just get the header?
Old Jun 10, 2004 | 08:48 PM
Civicr2gs5's Avatar
take it to a muffler a shop and have them do it....i'm pretty sure u can prolly get it done for pretty cheap like around 30 bucks
ABK's Avatar
ABK
Just get a set of EX/SI 92-95 headers *used*. They are cheap could pick one up localy for like $25-40. I assume that you are still running a d series?
Old Jun 10, 2004 | 08:49 PM
ApexIS300's Avatar
Default Re: CX Exhaust question (dogfood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dogfood &raquo;</TD></TR><TR><TD CLASS="quote">why not just get the header?</TD></TR></TABLE> come on man get the header ud be way better off
Old Jun 10, 2004 | 10:54 PM
The thing about just getting new headers, is that I plan on getting b18c1 within the next 3 months. I dont get the fitting for headers, do they all bolt up the same at the block? Will a sohc header fit a dohc engine? Are they transferrable to different series of engines i.e. EX header on a gsr engine? and if I get a new header for my civic, will I have to get a new cat as well?
Old Jun 10, 2004 | 10:56 PM
nwdave's Avatar
A SOHC header only works on a SOHC, and a DOHC header on a DOHC.
If I were you, as someone else suggested, I'd just take it to a muffler shop and have them fab up a little extra piping.
Old Jun 11, 2004 | 12:17 PM
Civicr2gs5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nw.dave &raquo;</TD></TR><TR><TD CLASS="quote">A SOHC header only works on a SOHC, and a DOHC header on a DOHC.
If I were you, as someone else suggested, I'd just take it to a muffler shop and have them fab up a little extra piping. </TD></TR></TABLE>
just like i sed.....btw if ur goin b18c1, ur gonna have to buy all the parts for the motor and for aftermarket exhaust, you can buy it for ur civic or u can go custom and have the muffler shop do it for you and remember to buy a cat for it or else ur **** will be hella loud which will cause you to get a big ticket sooner or later. That's my advice[QUOTE=nw.dave]A SOHC header only works on a SOHC, and a DOHC header on a DOHC.
Old Jun 11, 2004 | 02:32 PM
Synergy001's Avatar
just get a test pipe at http://www.racingpipes.com. it should work. it should bolt right up. it would probably cost more getting it done at a muffler shop.
JPRhome
Nov 9, 2014 06:30 AM
Adonis
Feb 23, 2009 12:35 PM
browniiiz
Jan 8, 2008 11:17 AM
lumnite
Nov 26, 2007 05:50 PM
93egSIboi
Nov 28, 2004 03:37 PM
