Do VIS Grade AA hoods clear DOHC heads?
Old Jun 10, 2004 | 03:18 PM
moleodonuts's Avatar
Default Do VIS Grade AA hoods clear DOHC heads?
Every now and then I hear somebody complain that their carbonfiber hood doesn't clear their head. I tried a few searches on HT but couldn't find any threads on the subject.
So I'm wondering, anybody out there have a VIS Grade AA OEM hood and have clearance problems with their engine?
I'm gonna be using a b18a bottom end with b16a head if that's of use to answering my question...
Old Jun 10, 2004 | 05:37 PM
Default Re: Do VIS Grade AA hoods clear DOHC heads? (moleodonuts)
man I thought this one would be a quick-answer <bumb>
Old Jun 10, 2004 | 06:02 PM
ApexIS300's Avatar
depending on the motor and mounts it should
Old Jun 10, 2004 | 06:04 PM
Luserkid's Avatar
Default Re: Do VIS Grade AA hoods clear DOHC heads? (SleepyCx)
Stock mounts, B18c motor and i had the biggest gap ever. It pissed me off, so i took a dremmel and cut pieces that hit the motor and then i put some hood pins to make sure its on there good. No problems since.
Old Jun 10, 2004 | 06:25 PM
Fred n J_v2.0's Avatar
b18c5-eh2 has had some first hand experience with vis hoods...
https://honda-tech.com/zerothread?id=572161
Old Jun 10, 2004 | 06:27 PM
BradsJDMGSR's Avatar
if you get the OEM hood it clears if you get one of those rycer hood with all the ugly vents.. BAM
Old Jun 11, 2004 | 12:05 PM
Default Re: (BradsJDMGSR)
Aight, so it sounds like this hood is not gonna clear, especially with my 1.8L bottom end. Anybody got any suggestions for a brand that'll clear?
freedm
18
Jan 14, 2009 07:08 PM
db8gsr_teg
Feb 28, 2006 08:51 AM
pvt_awol
Nov 4, 2004 02:11 PM
rhetorical
18
Sep 14, 2004 09:32 PM
apexinghonda
May 24, 2004 01:28 PM
