intermediate shaft, stripped bottom bolt hole. wtf now?
Old Jun 10, 2004 | 01:54 PM
hondaZvic's Avatar
Default intermediate shaft, stripped bottom bolt hole. wtf now?
yeah.. just like it says... the bottom bolt hole on my block has been stripped out... all the threads came out with the bolt... this is the bottom 1 of 3 holes that bolt the half shaft to the block...
any suggestions on how to fix this? can that hole be rethreaded and then use a bigger bolt?
open to suggestions..
Old Jun 10, 2004 | 01:57 PM
JDMotive's Avatar
Default Re: intermediate shaft, stripped bottom bolt hole. wtf now? (hondaZvic)
you can just rethread it or maybe use a helicoil..ive used only 2 bolts before because of stripped threads and had no problems though.
Old Jun 10, 2004 | 02:06 PM
hondaZvic's Avatar
Default Re: intermediate shaft, stripped bottom bolt hole. wtf now? (JDMotive)
whats a helicoil?
u think the 2 top bolts will hold it good enough?
i plan do do some serious 1/4 mile track attacks in the near future.. would hate for that shaft to somehow rip off and cause who knows what kind of damage...
Old Jun 10, 2004 | 02:09 PM
JDMotive's Avatar
a helicoil is basically a replacement thread..you have to drill out the hole that was stripped and insert the helicoil..theyre made in different sizes and thread pitch,so there should be an application that works perfect for that hole.They sell them at auto parts stores.
Old Jun 10, 2004 | 02:16 PM
hondaZvic's Avatar
cool.. ill look into that. thanks.
Old Jun 11, 2004 | 06:03 AM
1fastVX's Avatar
I had the same problem. Mine is now Helicoiled and holding great! Just go to napa auto parts and bring the bolt with you and order a Helicoil kit. Make sure you also buy the correct drill bit to go with it...its only a few $$ more.
John
Old Jun 12, 2004 | 02:57 PM
mike1114's Avatar
Default Re: intermediate shaft, stripped bottom bolt hole. wtf now? (1fastVX)
curious, how do you drill out hole if you can't take motor out? I stripped all three and now the bracket is just hanging there. I can't get a drill in there.
Old Jun 12, 2004 | 03:58 PM
hondaZvic's Avatar
Default Re: intermediate shaft, stripped bottom bolt hole. wtf now? (mike1114)
i forgot what they are called.. but there is a drill that has a joint on the end.. so it can pivot up to like 90* i think. (for them hard to reach places )
anyone know what im talking about?
Raebranch
Jan 5, 2017 09:29 AM
spidermancivic
Aug 11, 2007 08:17 AM
rzz
Mar 8, 2007 07:33 PM
Hoosier Daddy
Sep 13, 2003 02:25 PM
