ITR/Skunk2 cam (GSR Motor)
Well I am looking into camshafts and am wondering which to go with. My motor is stock internally, so I know that if I went with the skunk2's I would need valvetrain upgrades right?
However, I am leaning more towards the itr ones b/c of cost and they are not too aggressive. But will I see a satisfying difference in switching from my stock gsr's to these? I just dont want to fork out teh dough and not see a noticalbe difference.
Also if I did go for the skunk2's what mods to teh valvetrain would I need and would it be safe?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BERT-O »</TD></TR><TR><TD CLASS="quote">
stg 1s on OEM ITR valvetrain will do good, though, MUST BE DYNO TUNE!!!, before you see result.
What comp is this motor at?</TD></TR></TABLE>
Im not sure I understood your post fully, but let me try and decipher.
Ok so the skunk2 stage 1 is fine, but on a gsr valvetrain b/c I dont have an r motor, its the other B18C
My car is dynoed and plan to re-dyno it after cams. If you are saying comp as in "compression" its stock. No head work done, not even gasket.
So what would you recomend I do. Should I even bother getting stage 1 or will there be equal power with itr camshafts? And with a stock head will this be fine?
