Aaaahhh! help!
Old Jun 10, 2004 | 11:08 AM
Awar318's Avatar
Default Aaaahhh! help!
I can NOT get the bolt out from where the rear shocks connect with the arm.
Ive sprayed it with penetrating spray on it, hit the breaker bar with a hammer, I put the end of a breaker bar in a tire iron and tried to pull on that and that snapped the 14mm socket. How the HELL do I get this thing off?!
Old Jun 10, 2004 | 11:18 AM
Awar318's Avatar
Default Re: Aaaahhh! help! (Awar318)
Someone ..
Old Jun 10, 2004 | 11:28 AM
SkRiBLaH's Avatar
RedHackBatch's Avatar
pb blaster....keep trying and if that doesnt work just cut it off and get new bolts. most cars that i have had experience with the bolt just broke off.
Old Jun 10, 2004 | 11:47 AM
Awar318's Avatar
Default Re: Aaaahhh! help! (RedHackBatch)
gg skriblah.
Buy me the gun and compressor and ill use it. You think im stupid?
Old Jun 10, 2004 | 11:49 AM
JimmyAtlantis's Avatar
I had a shop do my suspension so I didn't have to deal with that problem. They just PB Blasted it and torched it some and they were able to use all of the original bolts and bushings.
Old Jun 10, 2004 | 11:52 AM
2OOOsi's Avatar
Default Re: Aaaahhh! help! (JRI94)
from my experience just heat it with a 10-15 dollar propane torch you get at your local hardware store. hopefully it'll expand and come off easier.
Old Jun 10, 2004 | 12:10 PM
jiggy's Avatar
Default Re: Aaaahhh! help! (2OOOsi)
^^^ wtf.. if the lca hole expands.. the bolt will expand too.. and it will be the same ****..
Old Jun 10, 2004 | 12:12 PM
menkio's Avatar
yea, don't bring it to a shop. be a man and do your own work... lol
pb blaster, torch, heat that ******* bolt up to all hell. get one of thoose high temp torches, let that on there for 5 mins. out like pie.
and "jiggy' a lot of people use this method. i've done it in the past, kthnx
Old Jun 10, 2004 | 12:17 PM
Default Re: Aaaahhh! help! (DewMota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DewMota &raquo;</TD></TR><TR><TD CLASS="quote">yea, don't bring it to a shop. be a man and do your own work... lol
and "jiggy' a lot of people use this method. i've done it in the past, kthnx</TD></TR></TABLE>
Sorry you little bitch punk. I don't live with mommy and daddy to borrow thier car in case I ef mine up and I have places I have to go...like my job...that pays me...so I can mod my car. And look! You said the exact same thing as me. What a turd!
Old Jun 10, 2004 | 12:29 PM
Slava.'s Avatar
I had to cut mine off.
Old Jun 10, 2004 | 12:38 PM
JDM PRO's Avatar
get a long hallow bar and stick the wrench inside.
Old Jun 10, 2004 | 12:48 PM
AMG's Avatar
AMG
Default Re: Aaaahhh! help! (JDM PRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM PRO &raquo;</TD></TR><TR><TD CLASS="quote">get a long hallow bar and stick the wrench inside.</TD></TR></TABLE>
Thats a breakerbar and yes he already mentioned he had used this meathod
Old Jun 10, 2004 | 12:56 PM
Awar318's Avatar
Default Re: Aaaahhh! help! (dohcVTEChatch)
Yeah that method snapped the socket.
And I snapped another one too so ive replaced it twice today. Good thing its a craftsman ..
Old Jun 10, 2004 | 12:57 PM
3.3.3's Avatar
whatever you do, dont strip the bolt.
i did that on my old ek, and i had remove the whole arm just to take the springs off.
Old Jun 10, 2004 | 01:30 PM
AMG's Avatar
AMG
Default Re: Aaaahhh! help! (3 3 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3 3 3 &raquo;</TD></TR><TR><TD CLASS="quote">whatever you do, dont strip the bolt.
i did that on my old ek, and i had remove the whole arm just to take the springs off.</TD></TR></TABLE>
Mine is rusted shut and stripped from previous owner trying to take it off
I have to get a used arm from the junkyard b/c this bitch is stuck, even the shop couldnt get it out...
Old Jun 10, 2004 | 01:48 PM
KingDsi's Avatar
If i remember correctly, that is one of the bolts that has grooves running the length of the bolt. Over a period of time the bolt rusts and the grooves and the rust make it harder to spin the bolt. Another thing is, when the car is jacked up and the suspension is fully down, the control arm is not perfectly squared between it's connecting points of the chassis and strut. This also creates a problem turning that F*^#* bolt. If you have no access to an impact gun, have patience and use the PB blaster. Spray it all over the whole bolt and even where the strut connects to the control arm. Spray it some more. I never used a torch and I have done a lot of honda suspensions.
Good luck
Old Jun 10, 2004 | 02:17 PM
Awar318's Avatar
Default Re: Aaaahhh! help! (KingDsi)
Well, im taking a torch to it tomorrow to try and get it out.
Im going to need new bushings correct?
Old Jun 10, 2004 | 02:23 PM
KingDsi's Avatar
If you don't cook them, or they are cracked/squashed to bad, no. Just try heating the end where the nut is, then the head. But I would try letting the lubricant sit, tap it with little force (don't pound it) then try again.
Old Jun 10, 2004 | 02:24 PM
Awar318's Avatar
Well, one bolt already snapped off so ..
Im really pissed off right now. I dont know what I need and what I dont need and if I can get what I do need by tomorrow.
Old Jun 10, 2004 | 02:28 PM
KingDsi's Avatar
See, that bolt has the latteral grooves, and is pinched all over the place (on top of the rust on the bolt/nut end). All things considered make it one of the toughest bolts to turn.
Old Jun 10, 2004 | 02:30 PM
KingDsi's Avatar
Where did it break?
Old Jun 10, 2004 | 03:40 PM
Awar318's Avatar
The head of it broke off.
All I need to know is if im going to need new bushings. Thats it.
Old Jun 10, 2004 | 05:48 PM
93Civac's Avatar
Both my rear bolts were rusted in place. I ended up breaking them. I was able to get the strut off the lower arm, and I had to drill a little hole between the bolt and the side of the hole so some WD40 would get down in there. Then i took another bolt the same size and hammered it back and forth till it broke loose and finally came out.
Old Jun 10, 2004 | 05:53 PM
BanEL's Avatar
Default Re: (93Civac)
forget about new bushings, that bolt is in there for liFE...
and even if u do replace the bushing, u'll need a press, and its better off buying a whole new arm
i wouldnt waste my time with that lca anymore. go pick up some fancy srr shizzi, or used lca's cuz those are FOOKED
