Need help removing CRX antenna
Old Jun 10, 2004 | 10:24 AM
JDM2ndGen's Avatar
Default Need help removing CRX antenna
well the antenna is broken on my girlfirends crx and we have a parts crx with working antenna and i was wondering how would i go about removing it to put onto my girlfriends crx ...any help would be appriciated ...thanks...
Old Jun 10, 2004 | 10:32 AM
ghost_ryder35's Avatar
Default Re: Need help removing CRX antenna (JDM2ndGen)
its two screws on the top of the antenna. it looks like an oval where the antenna is, there is one screw on both sides of it.
Old Jun 10, 2004 | 10:33 AM
crx_88_si's Avatar
I would detach it from the radio. un-tangle or back it out so all that is left is the part that goes up the pillar. unbolt the actual antenna base and pull it out.
afterwards get a coat hanger and straighten it out. drop/slide it down the antenna hole. Attach the new antenna to it and continue to pull it out from the bottom. the rest so be self explanitory.
Old Jun 10, 2004 | 10:35 AM
JDM2ndGen's Avatar
Default Re: Need help removing CRX antenna (ghost_ryder35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghost_ryder35 &raquo;</TD></TR><TR><TD CLASS="quote">its two screws on the top of the antenna. it looks like an oval where the antenna is, there is one screw on both sides of it.</TD></TR></TABLE>i know that ...but once there off when ill pull the antenna up it looks like two tube that go down into the window pillar and it seem like there attached there and i dont want to break anything ...ya know ...do you know what to do from there ...because it doenst seem like it will pull and pop right out ...
Old Jun 10, 2004 | 10:37 AM
JDM2ndGen's Avatar
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">I would detach it from the radio. un-tangle or back it out so all that is left is the part that goes up the pillar. unbolt the actual antenna base and pull it out.
afterwards get a coat hanger and straighten it out. drop/slide it down the antenna hole. Attach the new antenna to it and continue to pull it out from the bottom. the rest so be self explanitory.</TD></TR></TABLE>ight i got ya ... thank for the info
staticCRX
May 4, 2006 03:28 AM
CrazyModGSR
Jan 13, 2004 12:36 PM
silox
10
Nov 15, 2003 06:38 AM
beaterman
Aug 20, 2003 05:50 PM
HondaPartsHero
10
Jul 20, 2003 09:44 AM
